Page 8 of 9
Re: [ REVIEW ] After Market Rear Sets.
Posted: Tue May 08, 2012 9:53 am
by bikemonkey
porndoguk wrote:bikemonkey wrote:Le_Blur wrote:As they say in freestyle BMX: "No brakes, no mistakes".
Haha, I run brakeless on my bmx, it's more like "brakeless is the way forward".
No wussing out once you've got the speed up
I only run a front on my Diamond Back
Haha, not seen someone run front brake only on a bmx in yearssssss.
Not seen a diamondback in a while either
But what you have to remember is.....
The only difference in stopping is this:
you can stop with your feet on the floor or in the back wheel, and this:
needs something more than rubber soled shoes......
Posted: Tue May 08, 2012 11:56 am
Respray?
Posted: Tue May 08, 2012 12:15 pm
by bikemonkey
Respray?
On which? Not following you here
Posted: Tue May 08, 2012 12:31 pm
by Cammo
Neosophist wrote:
Respray?
I'm guessing they're Chinese panels.
Posted: Tue May 08, 2012 12:33 pm
by bikemonkey
Cammo wrote:Neosophist wrote:
Respray?
They aren't original I know that!
But I don't think they're bad quality at all. The paint is good, just missing a couple of decals and a rough edge on the seat unit which is as you can see covered by that silver strip.
I thought he might be on about my flamboyantly coloured BMX
Posted: Sat Jun 09, 2012 7:49 pm
by xivlia
update on the rearset... they are good, but not initially. initially they where shite! i almost cried for spending 120 quid on them.... but once i adjusted it to my feet and the angle, it was good. there is another problem, its the fact that almost everything is detachable.... and it is ideal to use a thread locking compound once you set it to your liking. otherwise it unscrews while you use it... like it did with me, the gear shifter end part kept on loosening as i used it.. so thread lock fixes it. not that anyone would buy these
but still wanted to share an update.
Posted: Sat Jun 09, 2012 8:04 pm
by porndoguk
xivlia wrote:update on the rearset... they are good, but not initially. initially they where shite! i almost cried for spending 120 quid on them.... but once i adjusted it to my feet and the angle, it was good. there is another problem, its the fact that almost everything is detachable.... and it is ideal to use a thread locking compound once you set it to your liking. otherwise it unscrews while you use it... like it did with me, the gear shifter end part kept on loosening as i used it.. so thread lock fixes it. not that anyone would buy these
Thread lock on gear shift! good luck ever trying to adjust personally id have slapped a bit of silicon in there far easier to get off but wont undo.
Posted: Sat Jun 09, 2012 8:19 pm
by xivlia
oh. il try that then! i find thread locking easy to brake off with a bit of heat.
Posted: Sat Jun 09, 2012 8:43 pm
by porndoguk
xivlia wrote:oh. il try that then! i find thread locking easy to brake off with a bit of heat.
Its a bitch when its been a while
Posted: Sat Jun 09, 2012 8:45 pm
by perculiarraddish
I can't wait to write this up as a Darwin Award candidate
Rock on Xivlia
