xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
Re: xivlia's thread of nc30 problems and questions
xivlia wrote: the engine spins and spins, and doesnt fire up.
So why would you think this a problem with the starter? when you say its jamming this wouldnt happen to be after you've been turning it over for ages would it?
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
the engine turns over. and then CLONK :\
xivlia
Post by xivlia »
no, im not spining it for ages, just a few times.. and bike doesnt start.. but most of the time, it just spins a few times and then jamms with a big clonk. and then i have move it back and forth to fix the jamming, and then try again... same thing happens... spins, a few times and then clonks :\ it cycles through like that... spins spins spins, clonk.... after a few 10 minutes..... spins spins spins... clonck etc etc..
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
post up a video of the bike doing this maybe
Deviants AM/PM build
viewtopic.php?f=62&t=27307
xivlia
Post by xivlia »
i will.. but ive got everything drained at the moment. and im gonna wait for Mo's starter clutch to arrive, im going to use that next time. and i hope it fixes it... if it doesnt, il post up a video on it.
mo haggs
Bike owned: bikeless
Post by mo haggs »
Put a wrench onto the center nut on the starter clutch and turn the motor over by hand 5-10 times and see if it jams then.
xivlia
Post by xivlia »
il try that as well. did you get my paypal?
Bike owned: VFR400
Post by magg »
As you have the clutch removed , why not disassemble it? Functioning correctly in your hand may not mean it works correctly under load.
mo haggs
Post by mo haggs »
yes i got the funds and will put the starter clutch in the post first thing tomorrow morning.
as MAGG says, strip down the one you have and see if anything obvious is wrong.
you're getting another one so it won't matter if something goes wrong.
but still crank the engine over by hand,
i'm a bit concerned that there may be somthing a bit more sinister going on.
can you still start the bike by bumping it?
if so - when the engine does fire up does it run ok?
xivlia
Post by xivlia »
hmm. okay i shall remove the 3 bolts. and see whats in side it.
Locked
