Exhaust badges. TSR related
- Yakama
Re: Exhaust badges. TSR related
Got mine today with a few other tasty bits from moriwaki man.
Thanks again Tony for organising this.
Got the badge yesterday, looking forward to adding instant kudos to my my cheapo chinese carbon muffler...
A big thanks to Tony (DM) for organising this deal.
						- micpec
Yours travelled alot, Cammo..."first made in Japan, then shipped to the UK and then forwarded to the otherside of this globe...into OZ"?Cammo wrote:Got the badge yesterday, looking forward to adding instant kudos to my my cheapo chinese carbon muffler...
 Well, for sure it is definately worth it!!
Yes worth it, nice bit of gear.
What's everyone using to stick them on to their mufflers?
Glad everyones received them and are happy.
Cam, i just peeled the backing off and stuck it to a hot exhaust. Before peeling the backing off tho i shapped it using a spray can.
- BillingCBR
one of mine came loose at the edges and pretty much fell off when I touched it, despite thoroughly degreasing before application  I'm going to rivet both on with some tiny rivets, hopelly will look decent when I'm done.
Your tip on using a spray can was good Tony, I lined the seam up with the writing and then gently bent it round the can, and it fitted perfectly :D
 I'm going to rivet both on with some tiny rivets, hopelly will look decent when I'm done.Your tip on using a spray can was good Tony, I lined the seam up with the writing and then gently bent it round the can, and it fitted perfectly :D
Yeah that's what I was worried about.BillingCBR wrote:one of mine came loose at the edges and pretty much fell off when I touched it, despite thoroughly degreasing before applicationI'm going to rivet both on with some tiny rivets, hopelly will look decent when I'm done.
I think I'll use a couple of small rivets also, don't want this sucker to go missing!
						- BillingCBR
Not at the price they cost I wouldn't either! I'm using the smallest I got in a pack, I think they use a 2.5mm hole :)
Ok mine came off today so id advise rivets or at least some super strong glue
						- BillingCBR
 did you at least retain it or was it lost to the road?
 did you at least retain it or was it lost to the road?'89 CBR400RRJ and '91 VFR400R NC30 project
