xivlia's thread of nc30 problems and questions
- xivlia
- Bike owned: Ducati 749 D
Re: xivlia's thread of nc30 problems and questions
thought so. i will try with a breaker bar soon.
- xivlia
okay, the breaker bar didnt do the job... this thing is truly jammed in.... the gears will move and jitter even though its on 6th gear, the brakes pressed on hard.... used a cloth as well.... no use.... they just jitter about.
Which nut are you removing? The clutch nut?
You'll need to shock it - air gun, impact driver or similar. Or even more leverage....
- xivlia
yeah the clutch nut, the one in the middle. dont have impact driver or air gun etc. anyway i can lock the gears in place?
- Bike owned: VFR400
Thought you were removing the starter clutch?
Yes a ratchet strap or some tough denim like i first told you, if the gears are moving then what your using clearly isnt doing the job.xivlia wrote: anyway i can lock the gears in place?
Get an old pair of leather gloves and use one of the fingers in the teethDrunkn Munky wrote:Yes a ratchet strap or some tough denim like i first told you, if the gears are moving then what your using clearly isnt doing the job.xivlia wrote: anyway i can lock the gears in place?
- Deviant400
personally id be putting the person who sold you the bikes fingers in the gears
viewtopic.php?f=62&t=27307
Would be interested in clarification of which BOLT he is trying to undo.
Not an NC30 engine but the starter clutch is very similar.
This is what your undoing right?
