Re: NC30 dyno 45hp :(
Posted: Tue Mar 22, 2016 9:48 pm
I am curious, did you fixed that problem? because i am in a similar situation and still cant find a solution
http://www.400greybike.com/forum/
that low hp is likely knackered engine.. loosing compression thru worn rings / valve and not making proper power.demerdzhiev wrote:I am curious, did you fixed that problem? because i am in a similar situation and still cant find a solution
Nope. I am swapping the engine and will do a postmortem on the old one. Probably a combination of things. Old valve stem seals let oil in then everything got carbon deposits and now valves and rings are leaky.demerdzhiev wrote:i meant the a/f problem
