Page 6 of 15
Re: Carbon question.......
Posted: Mon Feb 27, 2012 9:37 pm
by Evilchicken0
Because they'll go into an oven to cure, glassfibre will expand and contract at a different rate to Carbon, so you use the same material for the mould.
Probably
Posted: Mon Feb 27, 2012 9:39 pm
by morepower
hunter wrote:Can i ask,Why you used carbon for the moulds And not glassfibre,as it would have been cheaper.
I used Carbon because this is a box section and it is still early in the year so it could still get cold over night. I used odds and scraps.. But when you make a mould that may need to be put in the oven overnight to cure the glass mould expands as it heats up and then the carbon cures in this now expanded mould. If the heater cannot keep it warm enough the glass contracts and contracts more than the now cured carbon. This causes two problems. One is the part locking into the mould the second is the 1mm thick carbon part will actually crack the surface of the mould and kill it.... It is about keeping things consistant and ensuring you do not damage the mould. One £200 carbon mould is worth more than making 2 or 3 £40 glass ones when you think about the time you lose making new moulds and time lost making parts you can actually sell......
Posted: Mon Feb 27, 2012 9:41 pm
by Drunkn Munky
This is a great thread, id like some chunky frame and swingarm covers in kevlar if you need something to do, for a NC30 of course
Posted: Mon Feb 27, 2012 9:45 pm
by morepower
Drunkn Munky wrote:This is a great thread, id like some chunky frame and swingarm covers in kevlar if you need something to do, for a NC30 of course
Waiting for a frame and swing arm to be dropped off at the moment.....
Posted: Mon Feb 27, 2012 9:57 pm
by Drunkn Munky
A kevlar set for me thanks
Posted: Tue Feb 28, 2012 2:07 am
by Morespeedvicar
And maybe a nc30 rear hugger, grp one would do!
Ian
Posted: Tue Feb 28, 2012 10:51 am
by hunter
Forgot about the oven,I must pay more attention.I must pay more attention.I must pay more attention.
Posted: Tue Feb 28, 2012 12:51 pm
by morepower
Its OK..... I call it an oven it is just a wheelie bin on its side with a 3kw heater keeping parts toasty warm as it cures and overnight.... But as it is on the low power setting if the temp drops subzero it is pulling cold air in to the heater and may not be hot enough to pull keep the temp constant.... I ruined 3 moulds with the cold snap.... So trying to avoid that happening again....
Posted: Tue Feb 28, 2012 1:27 pm
by Evilchicken0
Why not wrap the bin in loft insulation - it's cheap and effective
Posted: Tue Feb 28, 2012 1:53 pm
by Taggyd
or set fire to a honda 400 to give it extra warmth...
