Re: 3TJ Fan problems and overheating
Posted: Fri Oct 07, 2011 10:48 pm
				Yes your right!! All that it means without the stat is it takes longer to boil giving me longer to put the switch on.
But you are right it should have a stat!
I tried to get a pressure test a few weeks ago but due to the location of the cap they could not get the tester on. After it has been running for a few weeks I will get a block tester that will tell if any combustion gases are in the coolant.
Also talking to a radiator specialist today I am wrong about the pressure!! The pressure is created by the water getting hot not the waterpump! As the water heats up it expands and then the rad cap stays shut until the pressure builds up on the radiator and it lifts the cap when it reaches it's limit.
I can easily press the hoses together but there is enough pressure to lift the cap.
Maybe when I first had it and was getting it going all the revs has done something to the gasket or block? I find that hard to accept but possible. There are absolutely no other signs of anything amiss if I don't let it boil it looses no water, nothing in the oil or water, engine watertight and no tell tell signs coming out of exhaust. Plus the bike goes like a rocket and is always cool unless it is in traffic or is being reved at standstill.
The thought of removing the head and block is to daughting to think about with the engine I have.
I really don't know what else to do? My neice had a custom Honda that did the same and the RAC man just wired the fan to be on all the time. She rode it for 3 years like that after replacing the rad cap and fan sensor.
I don't want to do that for wearing out the fan, but like everyone else who have been so kind to try and help, I am sick of it and as I said I have no idea what to do know!
Thanks for posting!!!!!!!
