clock colour change
				Mr_Fen
Re: clock colour change
4 have gone already, I have received an update from the company, i should get the PDF proofs tomorrow.  I will post online ASAP.
				Mr_Fen
hopefully this link will work, PDF of the clock faces, I have already received payment for around 5 sets so if you want some click the 'BUY' link on pg4
http://www.facebook.com/album.php?aid=1 ... =732348660
- Deviant400
i really want some of them but skint till the end of the month will i be able to get some later on
viewtopic.php?f=62&t=27307
				Mr_Fen
@ deviant there are still some left (10+) as most people seem to be waiting for the end of the month, you should be in luck.
						- Deviant400
excellent   will paypal you some spondoolies when i get paid
				KD88
Hi guys, glad to see this group buy get off the ground. when I ordered my set I told lockwood there would be a market  and considered doing the same as Mr Fen.
Now to the fitting of them. The speedo is easy as the back of the clock unscrews, but the other two dont. For these you will have to open the bezel with a very small screwdriver, about the size of a craft or watch makers flat blade. Do a little bit at a time and wrap a couple of layers of plastic tape around the base of the housing to protect it from the srewdriver when you're levering the bezel up. When you've gone all around, then use a slightly larger blade to open the bezel more and keep working your way round until it is fully opened. You may need to lever the bezel off but be very careful as it is possible to crack the glass as I found to my cost. (had to buy another rev counter just for the glass)
To fasten back in I found the best way, was to start with some pliers to ease back the bezel edges (making sure you protect the glass and outer rim with some cloth padding. Once you have got the bezel bent over enough put the unit face down on a solid surface (again with some padding) and use a small diameter drift too gently tap the bezel back into place.
Unless you are master craftsman the finished result will not be perfect but a spray with satin black paint will help and when fitted back into the surround can not be seen anyway.
Just take your time and be gentle.
Hope this helps.
Hope this helps.
				KD88
This is what mine looked like when i'd finished.
				Mr_Fen
I have been expecting these to arrive this week, have got this email yesterday:
From: Lockwood International Ltd / Superdials.com [mailto:Sales@lockwoodinternational.co.uk]
Sent: 23 September 2009 14:05
To: Mr Fen
Subject: RE: dials for a 1992 Honda VFR400 (NC30)
Hi Mr Fen,
we are really sorry for the delay with your order. We had to order in some material to produce the dials on but we have now started production and the dials will be leaving us at the end of this week.
Once again sorry for the delay.
Kind Regards
Lockwood Int
I'll get the sold ones out in the post ASAP
thanks for the instructional pictures KD88, i'll be taking photos of my install too
To: Mr Fen
Hi Mr Fen,
Kind Regards
Lockwood Int
				Mr_Fen
I had a phone call on Monday from the manufacturers to say they had been posted, I haven't received anything myself yet.  I have chased them up this morning to get a tracking number or courier details and they are going to call me back.  Sorry for the delay.
				Mr_Fen
FINALLY!
I have them all, if you have paid already they will be in the post ASAP, if you wanted a set, hurry up and click on the link to buy them.
