Project RVF stocker...ish
Suzuki416
Re: Project RVF stocker...ish
The screen can be polished up to get the marks out. Use something like meguiars plastx and a polishing machine.. it works better than you think.
- Tim400GB
Just watched a few vids on the stuff, does it need reapplying after a while?
Suzuki416
Can't answer that. I did my headlight & screen it did a great job on that (although bought a spare light just in case).
- Tim400GB
Got some greygate stuff, was pretty dam good!
Screen is so much better now, shame the screen bolts I ordered turned up proper cheap and nasty. Have ordered a new set
Kept the sticker for the purists (all the dirt is on the table not screen btw)
vic-vtrvfr
Looking good chum! Did you use a machine buff or just elbow grease?
- Tim400GB
- Tim400GB
New screen bolts arrived, much better quality
New mounting rubber as the old one was knackerd
All mounted, with a bit of black vinyl on the screen to cover the back of the clocks.
Indicators work, main beam ok, dip on one of the bulbs fail, quick swap of the bulbs to check its not wiring. £20.43 for a new bulb it is then.
Got this lot to clean up now
- Tim400GB
Got an RVF exhaust can kindly donated by CMSMJ1, many thanks again.
Cut the weld and started smacking the internals out, would not budge, cut another mm off as there was an edge stopping it.
Finally got it all apart.
And I only hit myself the once, but boy did it contact, not broken but def done something. I know this because there was no shouting but a 5 min silent reflection on what had just happened.
Lesson learnt: hit wiser not harder
Next to figure out how to rework it with a removeable baffle and then test it.
- NGneer
LOL - that long silent moment when you are trying to work out just how much something hurt and if you actually need to do something about itTimon wrote: Sat Jan 19, 2019 9:18 pm And I only hit myself the once, but boy did it contact, not broken but def done something. I know this because there was no shouting but a 5 min silent reflection on what had just happened.
Bike is looking very tidy Tim...... as always
Suzuki416
[quote=NGneer post_id=388231 time=1548081503 user_id=2087]LOL - that long silent moment when you are trying to work out just how much something hurt and if you actually need to do something about it
. It normally involves a hand full of paper towels in my case and letting the initial shock/pain subside before I check just how much I am bleeding and if I actually need to call the Mrs or if a bit of masking tape will suffice
[/quote]
No - you never tell the Mrs - it just gives her ammo to shoot you with....
Unless you need her to drive you somewhere quickly.....
