Spark plugs FZR 400rr 3tj1
Re: Spark plugs FZR 400rr 3tj1
Post by Evilchicken0 »
If he doesn't know where the coils are then its unlikely they've been checked. I thought tight valves would be poor starting and running until the bike warms up and the head expands, this makes a bit of tolerance and valve seals. When the tolerances close even more the bike won't start.
Checking the fuel is getting to the carbs is an easy thing so I started him on that first.
chris6409
Post by chris6409 »
Will a leak on the down pipe cause it to run crap when hot
hunter
Post by hunter »
NO.
chris6409
Post by chris6409 »
This is really annoying me now the carbs and jets are clear and balanced valves are ok there is a small leak off one of the down pipes the KnN air filter got soaked in engine oil when some PO a**e overfilled the engine causing it to go into the airbox was ran on crappy old fuel before the carbs got cleaned i dont think its missfireing al though sometimes it pops but theres no loss of power only a spluttering when it warms up
If anyone has any idea
chris6409 wrote: the KnN air filter got soaked in engine oil
Hmmm have you cleaned it since ?
If not take it out and see if the bike still runs crap. The oil sitting in the air filter can change the mixture (making it over rich), if it runs better then you need to clean the filter, you need to use proper K+N cleaning fluid you'll be surprised how much dirt comes out, then re-oil it with the K+N filter oil.
levo
Post by levo »
If it is the coils give me a shout I have about 3 sets.............
chris6409
Post by chris6409 »
How can i check the coils and How much do you want for them levo and thanks evil i was gunna by a standard one because i thought if i dont rejet it after the k an n it will run like s**t is that not the case
levo
Post by levo »
I dont know how to check I have never had a coils break down.
You have Pm.
chris6409
Post by chris6409 »
Pm ? Email
chris6409 wrote:How can i check the coils and How much do you want for them levo and thanks evil i was gunna by a standard one because i thought if i dont rejet it after the k an n it will run like s**t is that not the case
The K+N doesn't add much to the airflow, the airbox is the limiting factor so it won't really need a rejet. It has to be clean though.
As I said before check the fuel and the fuel hoses
