Got a small amount done over the weekend;
Whitewall tyres anyone ?
No sense masking off a tyre that is only to be binned when the stickies arrive !
I hate painting alloy wheels,whatever you do some contamination is always in the alloy,but powdercoat is out of the budget on this project.
Headers cleaned up nicely,studs and nuts fitted and exup valve was stripped and copperslip greased.(only one previously snapped cap screw which drilled out and retapped easily).New plugs were fitted and cooling system replaced.
Presenty awaiting new supplies of fasteners.(before someone quips up about exposed overlength bolts.)
Tidied up clutch casing center, where paint was lifting, in situ (gasket is nearly £10),but am not really happy with the finish.It may get stripped off and polished instead.
After Boris' reply to an earlier post I utilised his idea and cut the tags off the shock remote res mount and relocated them.
This allowed tags to be fabbed and positioned to utilise the original hanger for the can .
The fixings are external to the seat unit but original  hanger is so bulky I did not wish to notch the plastics in order to fit it internally.
The original coolant reservoir is now refitted in its proper location.
Instruments and controls now refitted after fork overhaul.
As per usual,this was the first time they had been apart in 25 plus years.
New oil and seals fitted,the stanchions were much better than anticipated as was the condition of the bushings.
Heavier springs and new spacers to be fitted when sourced.
The legs cleaned up ok but some "worm trails" still remain in the alloy finish.
Braided hose for clutch routes through the frame and the replacement magnesium sprocket cover was given the wire brush treatment rather than paint.
Sidestand was replaced at the same time with one I had puchased months ago simply to get an original spring for another project.
The stand and pin had worn so much on the original that it settled another 10 degrees which was disconcerting.Nobody likes to see their bike lying on its side.
Headlight units refitted in anticipation of new fairing.
Uprated caliper fitted.
Starting to look like someone cares about it once more.
Whoever built this originally had thought it through and did a good job on the fab work,just a pity he chopped up an SP to do it.I think it has lain abandoned until very recently judging by the surface corrosion.
Now with the carbs serviced,plugs replaced,  airbox fitted properly and a decent can on ,it runs sweet as ...
The shake down run will be the decider if its to be a keeper or not.
Next weekend is the rear end overhaul, hopefully.
