'89 VFR NC30 - Wont start.
Old Painless
Re: '89 VFR NC30 - Wont start.
Post by Old Painless »
Is the petrol vacuum line on the right spigot on the fuel tap ? If you were riding for an hour it must be.
Take the idle adjuster out to where it is supposed to be instead of all the way in, that wont do any good.
Rustyp81
Bike owned: Cagiva Mito. VFR400R NC30
Post by Rustyp81 »
Hello all,
Manged to get to the root cause of the idle issue (i think) But now have developed another problem. The engine is slow to start and makes a very strange noise. I've uploaded a video to help you help me as my technical terminolgy is not the best
http://www.youtube.com/watch?v=U137i6gJvjk
Before starting here i drained and changed the coolent(50%water-50%anti freeze) as well as drain and change the oil.(yammalube 10/40 semi)
Please help
Russ
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 »
Rustyp81 wrote:Hello all,
Please help
Russ
That is a very bad noise :o I wouldn't try to start that again, you may be doing some real damage. Are you able to take the cam covers off and have a look at the cams and valves? I might be wrong but as the clicking/knocking is rev related it may be a bent/broken valve.
I am sure once some of the others on here have had a look at the vid you will get a more in depth answer.
Rustyp81
Post by Rustyp81 »
Everyone i have shown the vid to has made the teeth sucking noise lol.
I'm preparing my self for the worst and eyeing up replacement engines.
I would quite like to smash some thing right now.
skinnydog0_0
Well i hope the news is okay for you :pray:
that does sound fucked. Surely you can get the carbs off and the rocker covers and see whats what...
Bit of a nightmare this bike for you..it sucks. Saying that, am sure you can get it sorted. 8-)
Rustyp81
Post by Rustyp81 »
yeah, pretty much every one has said the same.
I'll have a look at the weekend when i've calmed down. Tempted to just buy another engine rather than messing around, either that or take the whole thing down the scrap yard. :down:
skinnydog0_0
Rustyp81 wrote:yeah, pretty much every one has said the same.
Hey i feel your pain, i had a similar thing about 8 weeks back. But if you do have a go at fixing it yourself, you will get to know your bike so much better and you will love it even more :grin:
Rustyp81
Post by Rustyp81 »
Couldn't sleep so have spent most of the early hours out side on the bike. Got the rocker covers off, and the cams and egg shapped things(rockers??) apear to be very dry compared to the front ones also when i try turning the engine by hand i meet resistance when the rockers highlighted are in the postition bellow.
I'm no mecanic but i'm guessing this is an oil starvation issues. and i'm also guessing at least one of the pistons is making pretty patterns on the walls of the cylinder, but is there any think i can do short of changing the whole engine and oil pump?
Russ
Rustyp81
Post by Rustyp81 »
Bit of an update,
Oiled all the egg shaped bits by hand(techinal i know) then tryied turning the engine over by hand again and a lot of the resistance had gone along with the squeaing/grinding noise had gone. there is still a little resistance in places but i can use my wrench to turn the engine with one hand now.
Noticed also that the the egg things pictured above and the ones too the right have marks on them, i'm guessing this is where they were rotating dry??
Am i pissing in the wind here??
Russ
