How to Video: Replace Clutch Plates (NC30)
iDemonix
Bike owned: '92 NC30
Re: How to Video: Replace Clutch Plates (NC30)
Post by iDemonix »
Man_Named_Dave - they're different. I bought a pattern part from eBay too called a "clutch and swingarm removal tool" but it only fits the clutch. Be careful though as they're pretty shit material, I managed to bend one of the arms on mine within minutes.
Can't remember if I ever said thanks for this video - but just in case I didn't - THANK YOU. This video was absolutely invaluable when I did my clutch, biggest thing I've ever done on a bike and your way was 10x easier than the Haynes book of lies which insisted you remove the starter clutch at the same time and so on.
I had the laptop close by with your video on the screen for hours!
Thanks again,
Dan
:rocks:
Man_Named_Dave
Bike owned: NC30(K)
Post by Man_Named_Dave »
Cheers, Demonix! I'll look for an original or quality CNC one.
jonnyb
Post by jonnyb »
Thanks for the video !
It made my clutch fitting this afternoon much more enjoyable :-)
The only thing I would add, in the hope that it might be useful to someone, is that I think its worth taking off the Sporket Cover on the otherside of the engine and greasing the needle bearings and plunger on the release mechanism I also buffed a couple of burrs out of the clutch rod at the same time.
Haynes manual has a couple of photo's of the above.
Thanks again!
Jonny
Sligeach
Post by Sligeach »
Sure thing jonny. That's important too but i was restricted for space on YouTube at the time so had to miss out on a few bits and pieces.
jonnyb
Post by jonnyb »
Hey,
I wasn't criticizing and meant it when I said thanks for the video, its great :-)
Jonny
Pusharder
Bike owned: Shiver, Harley, NC29 NC30
Post by Pusharder »
I take it you did the fork seal vid too.. If so thanks for that!
Sligeach
Post by Sligeach »
Yip clutch plates, brake caliper seals and fork seals. Now its up to someone else to do the others! Valve clearances, etc
makz2008
Bike owned: NC30, NC35
Post by makz2008 »
Helped for a smooth clutch change
Jashdown
Post by Jashdown »
Is it safe to file down the edge of the clutch basket? Won't cause any problems or anything? I'm going to have to do it if I find the notches on my basket when I fix the clutch.
lutorm
Bike owned: NC23, NC30
Post by lutorm »
My new friction plates have one tab painted blue. Are they supposed to line up with something on the clutch basket?
