NC30 carby jetting - DIY guide
bikemonkey
Re: NC30 carby jetting - DIY guide
Post by bikemonkey »
Surely you aren't unscrewing the pilot JET?
You need to set the pilot SCREW.
If it is the screw then something is wrong, might be chock full of seals.
RandomDan
Post by RandomDan »
bikemonkey wrote:Surely you aren't unscrewing the pilot JET?
Ignore me im being a twat!
Thanks :P
NC30Dubz
Bike owned: VFR400R NC30 (Polly)
Post by NC30Dubz »
This was amazingly helpful, thank you. I have to ask, I've got quite a loud, stubby exhaust can and I'm running jap factory spec main jets. If I was to change these to 4x120 size, is there anything else I need to change? Pilot screws etc.
Cammo
Post by Cammo »
NC30Dubz wrote:This was amazingly helpful, thank you. I have to ask, I've got quite a loud, stubby exhaust can and I'm running jap factory spec main jets. If I was to change these to 4x120 size, is there anything else I need to change? Pilot screws etc.
Generally no, just the main jets to change. The standard pilot screw setting is 2.5 turns out from closed, most NC30's with louder aftermarket mufflers prefer 2.25 turns.
I would recommend using new float bowl o-rings also if you're not sure when they were last replaced. Rick O sells great quality replica o-rings: viewtopic.php?f=64&t=42551
The same goes for carb rubbers - if the bike still has the original carb rubbers then expect a headache getting the carbs back on (if you can at all!). Rick O can supply new carb rubbers, also available from David Silver Spares or Honda dealers etc.
Glad it helped.
NC30Dubz
Post by NC30Dubz »
thanks, the pilot screws are currently set to 2.25, feels a bit boggy so thought id have a look at different jets. just emailed rick, hopefully have some new parts soon!
NC30Dubz
Post by NC30Dubz »
Ok so I got a set of 4x 120 main jets and a set of washers for the carb needles. Installed everything and now it won't happily rev over 10k. Very boggy. Could it be that the bigger size main jets (they were 110's) are overfueling the carbs? Thanks.
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
That's a good place to start. This symptom is on the road, right?
NC30Dubz
Post by NC30Dubz »
Ok. It could be fuel starvation aswell thinking about it, but I wouldn't understand why? Yes, it was on the road, took it for a run after fitting the jets and washers, was fine on a low speed run but as soon as I went full twist, the bike didn't like it
bikemonkey
I'd say that you need 118's.
I run 118f 120r with a half system, not just an end can, and it works great.
Have you got any washers under the carb needles?
Also is your intake standard?
NC30Dubz
Post by NC30Dubz »
I've got a yamamoto half system with a stubby exhaust, yes its a standard intake minus a bit of the plastic, there is 1 washer as standard on all the needles, added an extra 0.5mm washer to each at the same time as the jets.
