Scott's NC30 Track Bike Build
TZcRank
Re: Scott's NC30 Track Bike Build
Post by TZcRank »
Any idea why the handle bars are different weights ? The left is a fair bit heavier that the right.
TZcRank
Post by TZcRank »
Ok I'll just keep chatting to myself here lol. If the left being heavier than the right compensates for anything I won't benefit from it anyway as all three right side bars are bent on the bikes I have. So two left's with a hole for the throttle locater drilled will have to do for now. A set of turned ali bars will replace them in the near future.
TZcRank
Post by TZcRank »
Small update from the weekend:
Got the front rim sprayed and decided to clean up the front discs.
Used paint stripper to get the old black paint off. Quick sand and masked off ready for Satin black paint.
Got new wheel bearings and installed them too.
TZcRank
Post by TZcRank »
I couldn't understand why I had to fight with the top triple clamp to install it and the axle was also near impossible to get through the forks!
After a good think it occurred to me that something may be bent. I did find one bent fork tube in the set of forks that came off this particular bike.
A few measurements and a really good look at them I realised that the right hand side of the bottom triple clamp is twisted down and backwards!!
Thought it was odd that the front tyre had more wear on one side......must have been an interesting ride for the previous owner.
You can clearly see the twist in this pic I posted before:
CB1pod70
Post by CB1pod70 »
TZcRank wrote: Fri Jan 11, 2019 10:11 am I have a RVF 17 inch rear for the bike.
Has anybody run a 160 tyre (Pirelli Supercorsa) and did it affect handling / feel on the bike.
I know 150 is recommended but it will be far cheaper to get a 120 / 160 combo.
All the Guys I race with use the 160 / 120 supercorsa combo on their bikes (pretty much the tyre of choice for all 400's) so you will be fine. The biggest problem is getting hold of 17" RVF rears these days...
TZcRank
Post by TZcRank »
Thanks CB1pod70. I will be using a lightly scrubbed BT090 150 rear that I had in my stash and a new 120 front for the first event.
Would have preferred the Pirelli's but it came down to cost and the serious lack of budget this month.
TZcRank
Post by TZcRank »
Small update again. I turned some new ali wheel spacers, every gram helps lol.
Also found some factory brake pads in one set of calipers, that bike had just over 20k kilometers on the clock!!!
Also had problems with wheel alignment, couldn't get equal gaps between the forks and front wheel.
Eventually figured out that the axle is bent, by chance I rotated it and immediately saw the gaps changing with the wheel moving sideways.
So this bike had a bent fork stanchion, bent lower triple clamp and now the axle/spindle!
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Must have been a very interesting ride for the previous owner, how on earth do you manage to bend an axle.
TZcRank
Post by TZcRank »
cbr400rrn wrote: Sat Jan 19, 2019 11:25 pm Must have been a very interesting ride for the previous owner, how on earth do you manage to bend an axle.
Very interesting! As I said earlier, I was a bit confused as to why there was tyre wear on only one side of the front.
Initially thought the guy just preferred right hand corners lol.
Changed out the spindle for another one and voila, equal gaps!
I am now concerned about frame straightness......only used that chassis because it was the cleanest and had hardly any scratches ;)
Must have been a decent shunt to bend all that.....
TZcRank
Post by TZcRank »
Got a bit done over the weekend.
Finally got the 17inch rear and bought a new BT090 as the date code on the scrubbed one I had indicated it was approaching 6 years old!
Decided to get a set of aluminium bars turned end of last week
Sorted out the front calipers and levers so got the front end this far
