rvfto Cbr600rr 09 fork front end swap
micpec
Re: rvfto Cbr600rr 09 fork front end swap
Post by micpec »
I know marcus, but nothing mentioned about wheel spacers or other relevant parts to fit for example a front nc wheel.
Goulime
Bike owned: '91 NC29 / '93 NC30
Post by Goulime »
I don't know for cbr fork but for my Daytona one i had to deal with 24.5mm right and 20mm left
:peace:
Cru Jones
Bike owned: NC35
Post by Cru Jones »
Goulime wrote:I don't know for cbr fork but for my Daytona one i had to deal with 24.5mm right and 20mm left
:peace:
That's great information to have. I often consider this swap, but always wondered about the spacer issue and if you needed to do anything with the rotors to make them line up with the Triumph calipers.
...2T bikes exist and are ready to meet your 4T challengers. - ToraTora
The daytona calipers sit 2mm over the outside of the nc discs, its either bigger discs or machine the calipers. They work fine as they are though
micpec
Post by micpec »
So is it the Daytona (not -R) and the street triple (not -R) that I need plus spindle? The ones with radial 108 mm caliper mounts..? And to solve the 2mm overhang, fit rc30 discs = 310mm?
Maelstrom
Bike owned: MC22, 3TJ1
Post by Maelstrom »
Did the issue of the offset, which determines trail, get covered? I guess there is not much in it. The details I have collected thus far for Hondas shows little difference. http://litetek.co/Guide_USD_ForkDatabase.html
https://litetek.co
micpec wrote:So is it the Daytona (not -R) and the street triple (not -R) that I need plus spindle? The ones with radial 108 mm caliper mounts..? And to solve the 2mm overhang, fit rc30 discs = 310mm?
Thats what id do and if needed then space the calipers out as thats less destructive than machining the calipers. Or fit a 675 front wheel and discs.
You want the non R model daytona forks ideally, or the R model street triple as there the same as the stock daytona forks except for being a bit longer.
micpec
Post by micpec »
Thanks Tony, your info is very helpful as usuall !
So I've decided to stick to trumpets. Since this afternoon pair of forks and wheel and discs....all 675, all check 8-) Now on the radar a new carbon fender, radial calipers, new lines and new brembo rcs mc.
Are Brembo calipers any better versus 675 Nissin?
RickOliver
Post by RickOliver »
I stock the wheel spacers for the Triumph forks into RVF yokes conversion, I can also supply billet yokes to put 675/ST forks onto the NC30 frame.
James - I thought that the Street Triple forks were actually shorter than the 675 Daytona ones - my ST forks are 725mm from the centre of the wheel spindle to the top edge of the top nut - how long are your Daytona ones...?
Rick
micpec
Post by micpec »
Edit: I already sent to you my new order, Rick ;)
