GK76A O-Rings
Re: GK76A O-Rings
Sure they didnt have carb issues when new.
Re: GK76A O-Rings
Fair one M1KE.
Finally the carbs are sorted, apart from a minor compression issue with one of the cylinders, but that can be sorted no problem....so I'm told.
However, the issue now lies with the CDI unit. I'm not entirley sure what's wrong with it yet as it hasn't been taken apart yet. I read Ripzays thread about his CDI which only had a blown transformer (if my memory serves me) so I'm sincerely hoping mine is the same.
- Variablevalves suck
Re: GK76A O-Rings
Can someone post the sizes of the o-rings,
Inside diameter and thickness if possible.
Re: GK76A O-Rings
No one out there know the sizes? I can get viton 0-rings in any size, so if you guys post i can stick them on fleebay for ya!!!
Re: GK76A O-Rings
This guy gives the actual item codes for the o-rings
http://tonysleep.co.uk/gsxr400carbs" onclick="window.open(this.href);return false;
Re: GK76A O-Rings
There is more than just orings that need replaced most times usually you will need a needle and a fuel block oring and maybe a float bowl seal these bike are old if you like to continually piss with your carb then go about it the cheap way if you want to not be aggravated by in anymore then spend the money get the right parts...this is a common problem for these bikes....
Re: GK76A O-Rings
I'm thinking about selling my bike now. It's been off the road more than I've been able to ride it. It is supposed to be my only mode of transport and I can't afford to buy another bike, other wise I would, because I think it's a wicked bike.
I think the only thing left is the CDI unit to get fixed but, to be honest I've lost patience with it because I can't afford to keep doing this and I really don't know if there is anything more to do.
Re: GK76A O-Rings
Think this website is like your bike, keep getin hang ups and a white page.
Re: GK76A O-Rings
I'm getting that tonight as well....infact all day at work as well.
Seems ok now though.
Re: GK76A O-Rings
http://www.barnwell.co.uk/
The above website is for a company I get all of my O rings from for work. They stock all common sizes of o rings in imperial and metric sizes. Minimum order is £10 + VAT and if memory serves they charge £3.50 to post them. They definatly sell all the sizes you need for gixxer carbs as thats where I got mine from. They do all of them in viton too.
hope that helps someone.
