Disaster strikes
Keny73tj
Bike owned: Cagiva Mito, FZR 4003TJ
Re: Disaster strikes
Post by Keny73tj »
Got some plastex ready for it.
Must have been you I seen sneaking out the back gate whilst trying to get your leathers on and jump on to a black FZR ( they're faster in black too ;) )
Post by Evilchicken0 »
Sounds like it :grin:
Keny73tj
Post by Keny73tj »
She's taken shape over the weekend :grin: just off out for a quick shakedown. I'll get some pics today if time allows and show you all what I've been doing for the last 3 months!
Ta ta for now and thanks for all your help bighug
Keny73tj
Post by Keny73tj »
Wow forgot how well these bikes handle, borrowed a mates R6 a few times and it's quick but for sheer fun you can't beat a FZR 400! Everything seems fine except for a little fluid on right side of swing arm not sure if this is a little bit of oil from overflow pipe as a little was coming out when I changed the oil or brake fluid from reservoir (can't remember putting in the rubber part). Back brake isn't brilliant either so it could even be from m/c?
Apart from that she just needs MOT.
Bodywork needs a bit of attention in the future but will do for now
:rocks:
pearson*
Bike owned: FZR400RR
Post by pearson* »
Whenever I get fluid on the swingarm (right side) its normally from the overflow on the coolant reserve, or the top to it has slipped off slightly (or a little loose).
Tends to happen on heavy lean angles occasionally, or if you've topped up the reservoir tad too much
Keny73tj
Post by Keny73tj »
Image hi everyone, haven't been around for a while. Here's why I've been too busy enjoying her again, she's been fixed up for about 7 months and ridden nearly everyday thought I'd share a pic!
Get you with your gold forks :grin:
Looking good
