Page 4 of 29
Re: NC30 rear disc removing question.
Posted: Mon Dec 17, 2012 7:25 pm
by xivlia
i remember reading it as a 46mm nut, but i cant confirm it as the haynes is in the garage.
Posted: Mon Dec 17, 2012 7:28 pm
by speedy231278
It's just me being backward. I always think of say an 8mm nut being a nut that needs an 8mm spanner or socket, not one that goes onto a 8mm thread...
Posted: Mon Dec 17, 2012 9:34 pm
by Morespeedvicar
if i remember i'll measure it, if i can get at it, me garage is in a bit of eerrr mess at the mo!
Ian
Posted: Mon Dec 17, 2012 9:37 pm
by bikemonkey
It is 46mm, just loosened mine off the other day :peace:
Posted: Mon Dec 17, 2012 9:43 pm
by xivlia
i know i need large leverage to remove this, would you recommend using a big torque wrench? or could that damage the internals of the torque wrench?
Posted: Mon Dec 17, 2012 9:46 pm
by bikemonkey
Don't use a torque wrench, they aren't meant for un-doing things.
I got my dad to sit on my bike with it in 6th gear, front and rear brakes held on while I used my 2 and half foot breaker bar on it.
Saying that I didn't really unstake it the best I could have.....
Posted: Mon Dec 17, 2012 9:47 pm
by alexwitham
FYI
I did not manage to get the disc fitted without removing the hub.
Posted: Mon Dec 17, 2012 9:49 pm
Easiest is to use some for of impact driver/rattle gun...or failing that I use a 2 foot breaker with another tube onto it. No substitute for leverage.
Posted: Mon Dec 17, 2012 9:50 pm
by xivlia
okay no problem, il extend my current wrench, there are some hollow 2 meter long tubes il just slot that on the end of the wrench.... enough leverage :D
Posted: Mon Dec 17, 2012 10:14 pm
by speedy231278
By wrench do you mean ratchet wrench or spanner? I'd be a bit wary about putting a huge bar on a ratchet for the same reason as a torque wrench. Personally, I'd buy, beg or borrow a breaker bar. Yes, more expense, but if you break a ratchet by extending it with six feet of scaffold tube, you'll be having to replace it anyway.
