Re: what brakes fit nc35?
Posted: Fri Nov 09, 2012 11:37 am
14mm stock.
http://www.400greybike.com/forum/
yeah, VFRman steve sorted me out the top man that he isNeosophist wrote:Ah that will be the 92 blade then, did you get your MC sorted because I think I have a 92 blade MC knocking around..
NC35 was a 14mmCMSMJ1 wrote:What size is the RVF? 14mm? or 5/8?
they started fitting 14mm M/C after the initial run of 1992 modelsspeedy231278 wrote:Would be interesting to know what size it is, everything I've found so far for the Blade says 14mm (9/16) for 1992-1997. Wouldn't be the first time the aftermarket people got something wrong.....
Later ones deffo had 14mm.porndoguk wrote:yeah, VFRman steve sorted me out the top man that he isNeosophist wrote:Ah that will be the 92 blade then, did you get your MC sorted because I think I have a 92 blade MC knocking around..
again Rick Oliver said "What you need is not hard to find - it`s the master cylinder which was
used on the RC30 and early model Fireblades."
Ah, so it's like the very early NC30s where according to Mike Lohmeyer's page, the first particular number off the line had slightly different clutch plates to the rest of the same year? No wonder people get confused!porndoguk wrote: they started fitting 14mm M/C after the initial run of 1992 models
are these the ones your trying to flog for £90-100 in the for sale section?juggernaut wrote:What is the ratio of the front master cylinder?
I've just got some good condition sp1 calipers for £38!!!! and wanted to know the ratio as I may look at a fancy master cylinder.
Luke
porndoguk wrote:are these the ones your trying to flog for £90-100 in the for sale section?juggernaut wrote:What is the ratio of the front master cylinder?
Luke
