Re: Carbon kevlar engine case covers Nc29
Posted: Tue Jan 17, 2012 9:02 am
OK, I'll bite. Apologies if you don't like the answers, Gavin. Bear in mind that I'm down for a set for my race bike, so I'm obv a fan.
I think a lot of racers here in Aus (where it's a sunny 30+ degrees right now, BTW) use them because there is not much else available other than some bent 3mm ally, which is what was on mine before it went bang. If GB Racing, R&G, etc, made composite or ally/steel bolt on covers, I'd fork out. But they don't.
They are to protect your engine cases in the event of a crash. Should stop the cases wearing all the way through and allowing oil to escape (which is fscking annoying at a race meeting). Looking cool is a secondary consideration for those of us who are able to apply the throttle before the apex of the cornermarty400 wrote:Q1) What's the point the point of them, besides looking cool?
I've not noticed any temp difference between when I had them and when I didn't. There is a lot of engine under the tank, these wrap around a small part of itmarty400 wrote:Q2) Dosen't it hold in heat, like a thermal blanket?! Not desirable surely?
Yep. The ones I had only managed one crash each. One was a low side into Honda at Phillip Island, 80 - 90km/h, the other was a "major slide, smash the fairings up, hope I stop before we hit the wall" kind of crash at Winton. There was about half the material left after the PI crash, and I lost a lot more than a case cover at Wintonmarty400 wrote:Q3) Also, If one as a slide, it's a expensive replacement job?
I looked at their site, and didn't see any NC29 case protectors. So that would be a yes, these are a lot better than the nothing R&G have for the NC29marty400 wrote:Q4) Does it protect as well as r&g case protectors?
