HRC map ignitech
Re: HRC map ignitech
How would you identify one from the other,the one i have has no markings on it.RickOliver wrote:Check my post on the `Projex Dyno NC30 & NC35 HRC tests` thread - send me any hard evidence you have for Ignitech`s technical guy to work with and I`ll liaise with them to see if we can come up with a solution.
Can we confirm whether this is just a problem with the older V75 units or does the V80 give the same kind of results?
Rick
The software version of tcip4 will say it, they also have different versions of the programs and they dont work with each other, when did you buy yours.hunter wrote:How would you identify one from the other,the one i have has no markings on it.RickOliver wrote:Check my post on the `Projex Dyno NC30 & NC35 HRC tests` thread - send me any hard evidence you have for Ignitech`s technical guy to work with and I`ll liaise with them to see if we can come up with a solution.
Rick
I have one fitted still - it has a related version of what became the HRC map - the two traces are back to back runs.
The Ignitech was 2bhp down and the lines are basically the same. I do/did feel a better engine response with it though - crisp.
I bought mine second hand about 2 years ago,but i dont think it has ever been used.
i would imagin you have the older one then,hunter wrote:I bought mine second hand about 2 years ago,but i dont think it has ever been used.
i think from the know problems it would be safe to assume its the newer ones (v80) effected?
- Bike owned: ktm200exc gsxr400gk71b sv650
so everyone seems to have the same results, if it has better response wouldnt it show on the graph as more power .
- alexwitham
- RickOliver
Update -
With help from a couple of fellow 400gb members we have arrived at the solution to the missing top end power issue with Ignitech ignition units.
I`ll put up a new thread with a full explanation over the weekend and also get an emailable package together containing a DIY fix for anyone who needs it...
Rick
Rick
Brilliant, Nice one RickRickOliver wrote:Update -
Rick
Rick
- mo haggs
- Bike owned: bikeless
Does this apply to both 30 + 35?RickOliver wrote:Update -
Rick
