Page 4 of 5
				Re: Thundercat 3TJ
				Posted: Sun Jul 17, 2011 8:22 pm
				by Evilchicken0
				at a guess - yes
				Re: Thundercat 3TJ
				Posted: Tue Jul 19, 2011 7:18 pm
				by StreetFZR
				Evilchicken0 wrote:at a guess - yes
Any idea if I can fit the 400 Magnet (not sure of real name) to the T'Cat motor??
				Re: Thundercat 3TJ
				Posted: Tue Jul 19, 2011 11:18 pm
				by Evilchicken0
				If you found out the part number of the T'Cat and the 3TJ one you could see if they're the same
				Re: Thundercat 3TJ
				Posted: Tue Nov 22, 2011 3:33 pm
				by StreetFZR
				Been a long time since updated. Bike now has new Magneto off another T/Cat engine I bought.
Still wont fire but is trying, when turn ignition on revcounter runs to 8k stops then comes back, tried searching and come to nothing. Any tips on that??
I am going to take carbs off and clean out the fuel and check jets over, all other tips are taken on board need to get this sorted now its been to long
				Re: Thundercat 3TJ
				Posted: Tue Nov 22, 2011 9:42 pm
				by Evilchicken0
				Sounds like the throttle position sensor - either wire it to ground or use a Foxeye CDI
				Re: Thundercat 3TJ
				Posted: Wed Nov 23, 2011 11:58 am
				by StreetFZR
				Evilchicken0 wrote:Sounds like the throttle position sensor - either wire it to ground or use a Foxeye CDI
I am using a Thundercat loom and CDI would the TPS stop it firing??
Silly question but how do I wire it to ground??
				Re: Thundercat 3TJ
				Posted: Wed Nov 23, 2011 1:07 pm
				by Evilchicken0
				The Foxeye CDI doesn't give the diagnostic through the rev counter I think
Grounding out was Kayla's suggestion on the first page of the thread. The 8k dance of the rev counter happened in the sticky 600 conversion thread, have a read through and see how it was cured.
				Re: Thundercat 3TJ
				Posted: Wed Nov 23, 2011 4:35 pm
				by Kayla850
				The TPS shouldn't stop the bike firing, it's just a way of letting you know something's wrong. There should be three wires going into the cdi (maybe on a separate plug, I haven't got a Thunderace so can't say for sure) and if you connect either the blue or yellow to the frame it'll stop the tacho dance, or that's what happens on the TRX850 anyway. Have you checked for a spark, and are the plug leads on the right plugs? It's an easy thing to overlook and I've done it myself (which is why I much prefer singles
I've got a spare 4JH cdi if you need one.
				Re: Thundercat 3TJ
				Posted: Wed Nov 23, 2011 5:47 pm
				by StreetFZR
				Thanks Evil and Kayla, I will take a look tomorrow and look at my manual for the wiring to work out which I need to unplug.
Kayla that CDI may helpout also a little knowledge on hybrids aswel ha
I got  an interview tomorrow so depending on how that goes depends on when I work on my bike.
				Re: Thundercat 3TJ
				Posted: Wed Nov 23, 2011 5:49 pm
				by Evilchicken0
				Fingers crossed for both then
