Page 4 of 24
Re: Deviants nc30 strip and rebuild
Posted: Tue Jul 19, 2011 7:56 pm
by Deviant400
a little more progress made, got the swingarm back together and the engine back in the frame
the engine has had a fairly good clean up but needs a few paint touch up's, then will remove the water pump housing and the thermostat housing and polish up along with the sump and spray the speedo drive , some carbon covers should tidy it up a tad more,
i didnt really want to start pulling the motor apart as it really runs quite well so dont want to end up causing any probs by doing so, so i just chucked it back in the frame,.
Posted: Tue Jul 19, 2011 8:10 pm
by PeteJ
Looking mint!
Posted: Tue Jul 19, 2011 8:16 pm
by Deviant400
by Drunkn Munky
You did do the valve clearences before chucking the motor back in the frame didnt you, its a hell of a lot easier with the motor out the bike.
Its all looking very clean tho, good job
Posted: Tue Jul 19, 2011 8:24 pm
by Deviant400
yeah tony, i did the clearences last summer , and was a pain while in the frame , she aint done many miles since so im assuming there be ok for now , cheers for the comments
Posted: Thu Jul 21, 2011 9:31 pm
by Deviant400
ok not done much over the last couple of days as ive been a bit hectic but cleaned up the thermostat housing today from this ...
to this....
also got the loom back on but not sure if ive routed it right as stupidly i didnt take enough pics of this before the strip down ,
how ive routed it is,,, the centre of the loom (the big rubber grip) in the clamp on the rear rocker cover , then it goes to the right side of the frame down "between the thermostat hose and the frame" to the connector block/fairing bracket on the right side of the frame,
then under the thermostat housing connecting the single wire to the stat, then it branches off , one branch goes off to the clocks along the outside of the frame up to the grip on the clock mount bracket,
the other branch goes through the hole in the forward right engine mount over the front rocker cover but outside the rubber flap so it runs "between the top rad and rubber flap" under the airbox intake down to the left into the wire spiral to the coil bracket on the forward left engine mount ,
hope that makes sense , can anyone confirm this is the correct way please ,
Posted: Thu Jul 21, 2011 10:53 pm
by Smev
Sounds right to me - thats the way mine is (from memory!!)
Posted: Sat Jul 30, 2011 5:21 pm
by Deviant400
few more bits and bobs done , real caliper overhaul
also found a great little torque conversion tool as my wrench is in ft/lbs or kg and not the nm in the haynes
scroll down to the free programs
http://www.boltscience.com/pages/download.htm
Posted: Tue Aug 23, 2011 8:36 pm
by Deviant400
not been doing much constructive on the bike just latley, but have been cleaning up more parts , ive stripped the fork lowers of there flakey chipped paint and gave them a few primer coats and then a few coats of satin black, i was going to go back to the original colour or close to but opted for the black to tie in with the frame , ive also stripped the clipon brackets back to bare alloy and polished up, gave the bars a new coat of satin too and the clutch lever bracket and front brake braket/master cylinder also in satin, its all looking very nice and fresh and not the tired scabby look that its been since ive owned the bike,
i did replace the left hand switch gear a while back so now i need a run/kill switch as my one is badly faded and grotty looking, the recent left hand one is ok so the kill switch lets the bars down now,
ill get some more shots of the little bit of work ive done over the last few weeks uploaded soon as i know we all like to see piccys
the tyga suzuka cowl will be going off to my mates (protintuk.co.uk) for white carbon wrap in a few days purley to see if it can be done as there are some complex curves and stuff , so its off for trial wrap , if it goes well then the rest of the bodywork and tank will follow, if it proves to be a nightmare then it will have to be plain white vinyl wrap or paint , the reason being that the carbon wrap cant be heated and stretched as much unlike the plain as it distorts the carbon affect too much and looks pants,
also id like to thank brooky for yet another fantastic set of graphics for the bike , a job well done im sure there gunna look fantastic on the bike after the wrap, your a star mate
Posted: Tue Aug 23, 2011 8:44 pm
by royster81
Keep it coming, great rebuild so far.
