NC30 wont start
spooner
Re: NC30 wont start
Post by spooner »
right i removed this part
from here
and now i canntot get it back on :(
how do i do this do i need to remove the carbs from the bike to do it as i dont really want to do this
please help :rocks:
Re: NC30 wont start
ooooohhhh :o
you didn't want to do that.. :scare:
it is a Grade A, class 1, top fuel major league BALLACHE to get that back on. :shock:
Why did you take it off by the way?
if you cannot get it onto the carbs with them there you are going to have to take the carbs off the motor.
You'll be best served taking the carbs off - look under them and see the 4 rubber boots that have 2 clips each? Undo the top clips - and then pull the carbs off.
put it back together and remind yourself never to take that off again....
Seeing as you have the carbs in hand, clean them, look at what jets you have etc and make a note of them. Don't be drilling the slides, or installing washers etc - that is for later.
Good luck 8-)
spooner
Re: NC30 wont start
Post by spooner »
Doh well that will give me something to do tomorrow
ibby4585
Bike owned: SP's
Re: NC30 wont start
Post by ibby4585 »
shit mate, you still having problems, oh well theres nothing like jumping in the deep end!!
Kris
spooner
Re: NC30 wont start
Post by spooner »
Right i have the carbs off, it was quite easy :) and i am guessin i need to split then to get the top plate back on, is this correct?
Re: NC30 wont start
No, you can get them on by some manipulation. Wouldn't want to reassemble them myself! :o
You should be able to manhandle them onto the plate without splitting.
After you get them on, you'll need to have a search for the "drill bit method" of carb balancing as they'll be out. Also have to check your chokes work OK as the linkages might be skewed a touch.
Good luck!
Cammo
Re: NC30 wont start
Post by Cammo »
CMSMJ1 wrote:You should be able to manhandle them onto the plate without splitting.
I usually slacken the 2 screws off that hold the 4 carbs to there so there's a bit more play to work with to get the top plate on.
It's not a real fun job whichever way you get it done. Make sure that none of the rubber intake stacks are covering carb holes - you'll see what I mean!
ibby4585
Bike owned: SP's
Re: NC30 wont start
Post by ibby4585 »
might it be worth buying a second hand set of carbs balanced off ebay? Around 40quid it might be a lot easier , and use the originals as a back up set. Thats if they aren't uk spec ones!
Kris
spooner
Re: NC30 wont start
Post by spooner »
right got it back together :grin: after gettin fed of working in the garage i took them to my room and watched top gear whilst putting them back together, also i thing i found out why it wernt running the two front carbs wernt sat in the rubbers properly on top of the engine as i didnt have to unscrew the two front retaining clips holding the carbs to the engine so i hope when its all back togethr it will all work fine. now i just need to check there balanced
spooner
Re: NC30 wont start
Post by spooner »
well its all back on the bike and it still aint going :down: i am starting to get very annoyed with it now, can anyone shed any light on what else it could be before i have to pay someone to look at it.
