Page 4 of 10
Re: '89 VFR NC30 - Wont start.
Posted: Sat May 15, 2010 1:47 pm
What about the idle screw adjuster by your left knee? Wind that in so it idles higher than std and then work back from that..
Posted: Sat May 15, 2010 8:17 pm
by Rustyp81
idel screw is all the way out mate. Just had a few pint's with a bloke that works at the local dealer recons the carbs need blancing. i recon this could get expensive.
P.s just seen you sig YZF750R ftw!!!!!
Posted: Sat May 15, 2010 11:11 pm
lol.
my yzf is a git
turn your idle screw in dude
Posted: Sat May 15, 2010 11:21 pm
by Old Painless
If the idle adjuster is all the way out the engine wont get enough air and will cut out.
Posted: Sun May 16, 2010 12:09 am
by Rustyp81
the screw is all the way out/in so surley that should mean it idels at the highest possible revs? When i had the carbs of i screwed it so that the screw bit at the top of the adjuster was pushing the the bit where the throttle cable attaches by turing it all the way out. I asumed that this would make it tick over at the highest possible tick over.
I know that's not a very techincal definition but i hope you get what i mean.
Posted: Sun May 16, 2010 12:15 am
Rustyp81 wrote:the screw is all the way out/in so surley that should mean it idels at the highest possible revs? When i had the carbs of i screwed it so that the screw bit at the top of the adjuster was pushing the the bit where the throttle cable attaches by turing it all the way out. I asumed that this would make it tick over at the highest possible tick over.
Kind if get you..
Get it running, wind this in and go from there...
My moto is a git to start, same deal, IMO
by Old Painless
The idle screw should be screwed in so that it pushes the throttle cam arm about 2mm, you will see the throttle butterflies open very slightly. You should screw it IN clockwise.
Posted: Sun May 16, 2010 12:36 pm
by Rustyp81
Right turned the idel screw as far as it will go clockwise. Choke out, no throttle...starts and sit at around 2k after 5 miniutes or so it goes upto 3k'ish. Try and ballance the revs with throttle and ease off choke. Once the choke is off i ease off the throttle and she stalls :S
Where do i got now, the scrapyard?? lol
Russ
Posted: Sun May 16, 2010 1:02 pm
by Old Painless
Why dont you wait for the o-rings i have sent you to arrive, fit them and then see what happens.
Posted: Sun May 16, 2010 2:01 pm
by Rustyp81
True true. But i do have a set of known working pilot screws in there atm :S
