HID ballast kits info
w00dzy
Bike owned: Aprilia RSVR Mille
Re: HID ballast kits info
Post by w00dzy »
Hmm, wonder if they are the same... thanks for your time.. Im gona get on it - was meant to be going to france over easter but my mate blew me out :( So plenty of time :grin: If the ferry was booked i'd have done it alone..
w00dzy
Post by w00dzy »
How about this kit?
Sounds like the nc29, nc30 and nc23 imports all have the same bulbs as standard :grin:
http://cgi.ebay.co.uk/Bi-Xenon-HID-Conv ... 3a59543537" onclick="window.open(this.href);return false;
Davez29
Bike owned: NC29 forever
Post by Davez29 »
w00dzy wrote:How about this kit?
Hey w00dzy I would give that one a miss, doesnt look right to me as its got two bulbs per unit. The one I had (LP has now) only had 1 bulb per unit and switched over via a spring. I got it from HIDS Direct at £65 delivered I think.
w00dzy
Post by w00dzy »
Cheers buddy.. going to wait and order them next week..
leopard_pagan
Bike owned: CBR400/600 Fighter
Post by leopard_pagan »
yup that kit doesnt look good.
even the older kits i had only have one bulb that is pulled in/out with a servo.
key search is:
HID H4 Hi/Lo kit
need to order some new connectors and get on with fitting Durkas set.
dr_46
Post by dr_46 »
i have connected 2 hi/low hid kits to my nc35 i wired it correctly all i had to do was connect 12v from battery and a good ground so i took it to the negative of the battery for safe keeping....i turned them on the ballast buzzed lights came on not so bright as they should have been they stay on for 10 seconds then dim out and dont turn back on....i have been pulling my hair out for over 2 days trying to figure out whats wrong but i cant....PPLLLEEEAAASSSEEE HEELLPP MMMMMMEEEE!!!... :x :cry:
w00dzy
Post by w00dzy »
Not sure buddy, going to get a kit end of the month.. been delayed a bit... moneys been going on petrol!!
leopard_pagan
>i'd put the ground to the frame. as to the rest of the problem, hard to diagnose as you may have (hard tho) fitted it wrong, the ballasts/bulbs may be a bad batch. sounds like the initial start up is there, but power runs out.
where exactly and how have you fitted the kit, have you cut anything, shortened the loom etc?
w00dzy
Post by w00dzy »
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
I have a kit like that in my NC. I also have a projector HID bi-xenon custom install on my 900RR Fireblade. I would really love to find some clear lenses for my NC so I can do the same to it.
