Page 28 of 30
Re: Another 'spare' bike
Posted: Thu Nov 05, 2015 12:35 am
by Tim400GB
Not tested properly yet, but yeah after speaking to a few guys at work who know far more than I do all said the same.
Need to get the bike to brands to get it noise tested to get a bench mark.
Posted: Thu Nov 05, 2015 10:43 am
by Drunkn Munky
What ID is your outlet? I got various sized baffles here.
There be some weekend trackdays coming up now at brands, just get the bike along and test it
Posted: Thu Nov 05, 2015 10:47 am
by Drunkn Munky
Just looked back through your thread and are you using that tsr can on a rvf system? I passed with ease at brands with that exact can on a rvf system
Posted: Thu Nov 05, 2015 3:44 pm
by Tim400GB
With ease?! Must be the open carbs.
Posted: Thu Nov 05, 2015 8:14 pm
by reverse cylinder jim
Timon wrote:With ease?! Must be the open carbs.
You could be right there Timon
Really struggled with noise with my track bike years ago once I went to open carbs. Mine always sailed through before I went down that route. Instead of using a baffle I always used some kind of restriction in where the can fitted to the system to pass noise test. That way it will pass without having to have a baffle present as if the Marshall/noise tester see's a baffle they usually write it on the sticker they stick to your bike so you can't remove the baffle after the noise test.
Posted: Sun Jun 19, 2016 7:13 pm
by Tim400GB
Well the baffle worked, down from 106 to 100! and I actually managed to give the bike a shake down
Bike behaved rather well, think it needs a better rider though
The only good picture really
Posted: Thu Nov 03, 2016 12:27 pm
by Tim400GB
So the bikes been used a handful of times, which means its needs more money spending on it.
Not so much of a budget bike anymore, that said it hasn't been that for a while now.
New upgrades in the form of a pair of PVM mag wheels.
conical rear wheel spacer
New Ti bolts from RLR for the front disks
Just need to pick the tyres up from Tony, buy & skim some bolts down for the rear disk, make some new front wheel spacers and fit a Rick Oliver chain spacer kit before I can fit them
Posted: Sat Nov 05, 2016 5:33 pm
by Tim400GB
Tyres picked up, need to get the disks swapped over before I can fit and balance them.
Titanium rear disk bolts skimmed and fitted.
Was just going to fit a chain spacer kit to clear the tyre but now I'm thinking of replacing them with a 520 set and putting the 525s on my other rolling chassis.
Posted: Sun Nov 13, 2016 10:32 pm
by Tim400GB
Getting somewhere with the 'endurance' front wheel spindle
Posted: Wed Nov 16, 2016 12:00 pm
by Tim400GB
Got the rvf front wheel off the bike and then got the disc's off so I could put them onto the PVM
Here it is all bolted up with the new Ti bolts. Need to get the Bridgeport valve and tyre fitted so I can make some spacers to centre it up.
