Porndoguk's SEED NC30
Re: Porndoguk's SEED NC30
Both compression and rebound damping there are three settings options.jetblack wrote:Cool.porndoguk wrote:Depending on how much adjustment you want itll will.need revalveing, ive set mine to all +1 above the middle, but im going to crank it to sport and see how i get on, its very springy. Like a pogo stick, however it still is an improvement and im happy with it.jetblack wrote:Porndog, how are you getting on with the bmw shock? I guess today gave you a good chance to test it.?
Springy means you gotta stiffen the damping up a bit...right?
Compression damping slow
Compression damping fast
Rebound damping
rick is it just me or are you mid panel screws mahoosive??
bike is looking mint pal! deffo one of my fav schemes!
get some sexy dzus fasterners for that mid lad
nomnom
nomnom
im not a fan of the Dzuz fastners tbh, my screws are M6 counter sunk then an alloy fairing washer, i prefer them.lizard821000 wrote:rick is it just me or are you mid panel screws mahoosive??
nomnom
Current Work and Updates :)
so the story goes, after Bruntingthorpe i decided to strip and rebuild my forks with a polished set of lowers, thanks to lizard. in addition ive always want the SP1 Gold calipers so i did just that, got a tatty pair of eBay For £45, gave them an overhaul and then sold my CBR600 ones straight on to recoup the costs.
also got some stainless 40mm M8s for the calipers aswell as some stainless bleed nipples
also youll notice i have stanchion sheilds from a CBR600F ive had to cut a tiny bit out as the dia is larger, and ive used a large cable tie to clamp them on, seems good to me. form over function
also i removed some fender mounts from a NC23 oem fender, messed around with lemon and baking soda, vinegar and lime juice, and then tried some cheap happy shopper 25p can of rola cola (red bull can size) and it removed about 80% of the rust down to a satin silver finish. drilled the 6mm fender holes to 10mm dia, put them in drilled 3mm holes and riveted them in place like the OEM honda fender no more pissing around to remove it at last.
Also recently removed and sold on my Carbon exhaust hanger as i was never over keen, plus i felt i had a bit to much carbon on the arse end, back to OEM again, with a polished, then brush finish with scotchbrite,
further more 6 spacers i had that kayla sent surplus to requirements, i found good use for 3 of them, one for the exhaust can mount hole, and in addition the 2 mounts on the subframe that took forever to undo due to the thread size after removing the pillion pegs.
also after about 2 months of searching for a 5/8 CBR900 master cylinder steve aka VFRMAN came to my rescue.
it came in a nice clean black and so i put to use a clean CBR600 clutch perch i had so they matched and took my back to stock further more.
Clutch Before
Clutch After
Readjusted my damper
My (Small) Workshop for the curious
Chain measuring Tool!
small screw and precision marked lines on the side of the door :D
Abba Stand customised to work in the tight space,
i need to contact abba this would make there stand 20x better
Exhaust off whilst i sort a problem with the carbon and STILL bunged just in case of the kids!
and rear set risers removed and back to normal tygas
Clutch Before
Clutch After
Looks good Ricky!
That's looking good.. Like the mod to the ABBA stand great stands but need a bit of room simple solution
Nice to see your bike in print, looking good Rikster
- alexwitham
Pic whore
- Tim400GB
Looking good.
Nice exhaust bung
Nice exhaust bung
