Posted: Tue Sep 04, 2012 6:09 pm
All Powder Coating done by Marmo Coatings - Rugeley
Full Stainless Steel / Titanium Bolt & Nut fixings ALL replaced.
Specs List - From Front to Back
Bridgestone BT090 Tyre,
Powder Coated (HRC) Gold,
Captive Stainless Wheel Spacers,
Crash Bungs Fork Bottoms (Coyote Moto)
Arashi Wavy Discs (Rick O)
CBR600 Caliper, (Rick O Brackets)
Goodridge Stainless Steel Braided Hoses, (DIY)
Fork Internals, (Rick O)
Carbon Fibre Front Fender,
UK 5w Osram Sidelight Bulbs,
UK H4 Osram Headlight Bulbs,
20A Headlight Relay,
MPH Custom Dial, (Lockwood)
Sprint Steering Damper
HRC Stem Bung
Alloy Yoke Nut (Tyga)
Alloy Handles (Rick O)
Renthal Pro Grip
Adjustable Brake & Clutch Levers
Q/A Throttle
Samco Hoses
Crash Bungs (Coyote Moto)
Crash Adaptor Plates (Kayla - Projection)
Full Tyga Sprung Stainless Steel Exhaust - 440mm Carbon Can
NGK Replacement HT Leads (Rick O)
Piper Cross Crank Breather
Carbs
125 Front 125 Rear
#35 Pilot Jets - 2.1/4 turns
Float Heights - 6.8mm
Needles (Rick O)
No Shims Fitted
NC24 Slides - 2.5mm Vac Hole
K&N Panel Filter
Tyga Carbon Lid
HRC Feeder Tray
HRC Fuel Tap Mod
Alcantara Seat Recovering Rider & Pillion
BMW S1000RR Shock
D.Faulkner Spring 800lb
R&G Shock Tube
Tyga Rear Sets
SES Toe & Foot Pegs
Alloy Height Adjustment Plates
Titanium Shift Rod
Carbon Fiber Rear Hugger & Chain Guard
RK Chain 520 Pitch
Renthal 15T x 40T 520
Torque Arm Spacers (Kayla - Projection)
Goodridge Stainless Steel Braided Hose - Through Swingarm
Arashi Wavy Rear Disc
Shark Fin (Rick O)
Carbon Exhaust Hanger
Solo Seat Cover (Sprayed By Drunkn Munky)
Ignitech CDI Ignition Module
Titanium Wheel Nut (Kayla - Projection)
Titanium Hub Nut (Kayla - Projection)
Titanium Pinch Bolt (Kayla - Projection)
Alloy wheel Spacer & Stainless R CLip Pin
Powder Coated Rear Wheel (HRC) Gold
Bridgestone BT090
HRC Stem Bung
Renthal Pro Grip
Q/A Throttle
Samco Hoses
Carbs
125 Front 125 Rear
Needles (Rick O)
No Shims Fitted
K&N Panel Filter
Tyga Carbon Lid
HRC Feeder Tray
HRC Fuel Tap Mod
BMW S1000RR Shock
R&G Shock Tube
Tyga Rear Sets
SES Toe & Foot Pegs
Titanium Shift Rod
RK Chain 520 Pitch
Shark Fin (Rick O)
Bridgestone BT090
