v4 engine novice
Re: v4 engine novice
just found a set of four brand new denso for £32 one ebay! will let you know how i get on with the battery issue.
- matt_vfr
- Bike owned: '89 NC30
Also, get yourself on over to the new members section and show us your bike
Glad its sorted :)
Matt
Glad its sorted :)
Matt
i will head over there now but there aint much to see as she is frame and engine!
- Bike owned: zx9r c1
when you get youself sorted with a new battery test the charge rate just to make sure tha charging system is tip top.
william
william
i am dropping the battery off today for the dealership to 'test' and they will replace it if they find anything. So i will let you know i a day or so dependant on how quickly they work!
just for everyone info i have posted the pics of my blade and whats presently left of the nc30 on the newbie board.
cheers
chris
cheers
chris
Have you cleaned up all the earth connections?
yeah all earths were checked when i fitted the new loom, i think everyone including the garage now believe it is the battery once they confirm it to me i will let everyone know. I do hope so cos i want to get here running again asap.
ok got the battery back from the garage today, they charged it for two days, checked it after charge and under load and found no issues. i got it home put her on the bike, had lights etc as before tried to start her no joy.
added a bit of extra juice from my blade via jump leads and she fired, had no tank on so only ran on the fuel in the carbs / fuel line but was very rough idle ( i am expecting this as she has not run for four years as mentioned earlier )
she stalled after 2 / 3 mins running, went to try again with more fuel and all i got was a buzzing from the starter solenoid. not a click but i high pitched buzzing for as long as i pressed the starter.
now along with the battery i have had back, i have four new plugs and replaced the rectifier. so if it is not the starter solenoid i am out of ideas. the loom has been replaced with a known working one as mentioned, alogn with new plugs, rectifier and the battery has been checked so does anyone have any extra thoughts?
just been searching google and someone thad the same problem an r6, it turned out to be crap on the starter switch on the bars causing a bad connection stopping the fully voltage getting through so i will check that out as well tomorrow night after work and let everyone know if this seems to sort the problem but if anyone has any extra thoughts in the mean time please let me know.
Carbs need cleaning?
Hell knows what gunk is in there after 4 years sitting.
