Won’t start
Jordansilver1
Bike owned: Fizzy FS1E royal Enfield Grom
Re: Won’t start
Post by Jordansilver1 »
Also are all rectifier on Honda vfr400 nc30 the same as my bike is a L plate 94 I see these for sale on sites with certain years but plugs look same
Bike owned: VFR400
Re: Won’t start
Post by magg »
Given the conflicting readings between your dash mounted voltmeter and the charger, I would not continue to fault find until you have obtained a mutlimeter that can confirm either of the battery voltage readings.
Jordansilver1
Re: Won’t start
Ok thanks magg for your help really appreciate it I’ll pop down local bike shop later this morning to see if he can check the battery over
Jordansilver1
Re: Won’t start
Had battery tested in local
Shop he did a drop test and was 12.7v he said it was ok I also checked block on right side 3 yellow wires and all looks good so I better take it to local shop to do some tests
Jordansilver1
Re: Won’t start
Fitted new battery and bike started on first go so took bike to local shop he tested the battery and all was good but when I started her battery reading 15vupwatds 17v he said I need a new rectifier and he gave me a price of £95 for a moss one plus fitting as the new one comes with a new block and he likes to cut solder the new block also
Jordansilver1
Re: Won’t start
Rectifier I’ve been told is from electrex world RR58 £75+vat guy In local bike Shop said he would charge me to change the plug there is nothing know with my plug but he says it comes with new plug so he likes to fit it
