Project RVF stocker...ish
- Tim400GB
Re: Project RVF stocker...ish
Finally!
HRC TCI also turned up, can just about see the NKA code
- Tim400GB
Got the shock in, must say its quite a ballache compared to the nc30. Anyway its in without any scratches etc. Still need to mount the reservoir as Kais sent clamps that were far too big so had to order some new ones. Had to mod the exhaust guard a tad to be able to run the hose for the res too.
Got the battery and new strap along with the plug for the optimate.
Also did the air filter, not been changed recently
- Tim400GB
Forgot the take a before pic but the water pump had a load of that pink crust on it. Looks so much better now.
Start of doing the valve clearance check, started with the front head (cyl2+4). The exhaust pills could be somewhat challenging to get in.
The rear head was so much easier, although it had a few more bits to move out the way.
New plugs in with some high temp anti seize on the threads.
Woo valve lash done, slowly getting through the job list
- NGneer
Looking good Timbo
I spy on your list "Get single seat cover".
Not sure if the 30 and 35 are the same...but if they are, I have one sat on my shelves, could save you a few quid
- Tim400GB
Cheers Ian
30 and 35 are different, which do you have?
Clamps arrived, cut a couple of lengths of helitape to go around the resevior
and got it mounted
and got it mounted
- NGneer
Ahh - as I only have NC30s, I am guessing an NC30 seat cowl then
Looking good so far
Looking good so far
- royster81
Work is coming along nicely,
- Tim400GB
Got the front cowl and fender off to have the paint sorted. Hopefully get them back soon.
Before pics
Also a rear seat cover turned up for a good price, I did not turn down the offer.
Just need to paint it, got some black vinyl coming that will hopefully be a good enough match for the number boards.
Before pics
- Tim400GB
Few little jobs done
Old fuel out (and straight into the daily)
Top rad on
With new spigot from Kelfab
And fresh lower mount
Top rad on
- Tim400GB
Got some garae time so thought Id get the front end sorted, the seals were rusting and leaking.
The start
Forks out
Mid way cleaning everything up
Both legs done, new seals, bushes aswell as new springs from Rick Oliver
Back in
While the wheels were off thought Id get the rear pads changed (fronts are ok for the moment)
And get the new tyres on
And on the bike all torqued up, with a new split pin for the rear.
The start
Forks out
Back in
