Bike wont fire up
- Bike owned: FZR 400 RR 3TJ1
Re: Bike wont fire up
I was told yes
but having a head that's supposedly "good to go" was motivation to check everything else for the fault
You guys helped a LOT and quite frankly there was nothing else left to do but RELUCTANTLY check the clearances. Everything my brain was telling me (and what you guys were telling me) was being ignored by my heart
It takes no work at all to put a gauge on and saves days of wasted time fooking about.
I cannot fathom why that is not the first operation O.P.'s who have access to a gauge go for when purchasing non starters.
It verifies or removes the main non starting problem in one fell swoop.
Never ever take what a seller is declaring as gospel UNLESS you know his reputation.....disappointment surely awaits ...lol. (Fully rebuilt engine.{using all the same worn out parts} is a prime example)
Im not talking to you ANY more
you're always RIGHT
We cling onto every opportunity that might just be the cause, all the while, knowing full well (in the pit of the stomach) that its your worst suspicions. I shall consider myself bollocked out and will lick my wounds under the bench in the garage
Taking the good from this though - I bet it fires easily after you've done the valves
Actually it does take "work" on a 3tj mainly because of the access to the camcover and cams.
I swung the motor down, pivoting on the lower rear mounting bolt so there's a good deal of space.
If it DOESN'T fire easily it will immediately become a BOAT anchor
The next to no work referred to fitting a comp. gauge ...it easier than replacing a spark plug if the kit has the flexi connector.Evilchicken0 wrote:Taking the good from this though - I bet it fires easily after you've done the valves![]()
