My R4
joshua102
- Bike owned: Gsx-R600K9 3tj NC35
Re: My R4
The rubber coating on the Oil pump drive gear the gear has 6 lightening hole with only 3 uncoated (to allow oil pump to be installed). i used a lathe at work, and a plumbers blow touch to removed any small bits.
The BDK water pump kit comes with a very simple controller with two adjustable pots (on and off), i'm sure if you dropped them an e-mail they would sell you just the controller.
Joshua
Joshua
Maelstrom
- Bike owned: MC22, 3TJ1
Re: My R4
Thanks Dan. I got the details from them.
https://litetek.co
https://litetek.co
Re: My R4
When you paint bolts you don't really want paint on the threads, so ... order a pizza
Cut the lid off the delivery box and make holes in it with a screwdriver. Wire brush the bolt heads then drop them in petrol, it cleans the threads too. Wipe them in a cloth and stick them in the holes.
Now you can spray them in batches and they're held upright while they dry and you can find the bolts for each casing
Maelstrom
Re: My R4
Thanks Evil but the bolts have to be blasted before painting and then baked in the oven.
https://litetek.co
https://litetek.co
Re: My R4
Up to you how you prep them, but putting them on a board will make them easier to hold in the oven too
Maelstrom
Re: My R4
Gee it has been so long that it nearly fell off the forum.
Prepped the top end and painted
https://litetek.co
https://litetek.co
Re: My R4
Looks nice
Maelstrom
Re: My R4
Sneak Peak:
So wings gone.
and off to powder coaters
I am going to make an adjustable stand for it now so I can keep working in comfort.
Blair
So wings gone.
Blair
https://litetek.co
https://litetek.co
Maelstrom
Re: My R4
Hi All,
Been too long.
I made a stand with swivel bracket to hold the bike chassis and get to work on the headlights.
Then I had to cut and beef up the Chinese sourced R6 fairing bracket. Notice how thin it is. Also all of the grommet holes are too large, not round and different sizes. If you try to fit the OEM grommets they just flop about. I bored all of mine out to 18mm and used custom size grommets.
To fix the flimsy bracket I welded a piece of 6mm onto it etc, etc. The hole centres are wider on the FZR400 than the R6 so you have to cut and weld that first.
Cut the headlight holes and made fibreglass recesses
I am waiting for lots of bits and pieces now. The headlight bracket will be carbon. Should be some more updates soon as I am working on multiple parts at the same time.
Blair
Been too long.
Blair
https://litetek.co
https://litetek.co
