r1 front end one fzr400 1wg
- Bike owned: Honda nc29, fz400r, fzr400/600
Re: r1 front end one fzr400 1wg
Unfortunately not I just had to use the info given to me on the forum. Got there in the end :-).willandrip wrote:Nestor; did you ever find any manuals or parts fiches for the FZ400 ?
Hi sorry to thread jack
but with this setup would you be able run the R1 front wheel with the R1 disks and calipers?
im just starting a full rebuild/Upgrade on my Fzr400 3en2 1wg
and im looking for USD forks the ability to utilise the caliper brackets and upgrade the front brakes at the same time would be a massive plus for me
cheers Ollie
cheers Ollie
Ollie; you use the complete front end for this mod inc. wheel.
The work is in getting the steering stem swapped over (its discussed earlier in the topic)
There are another couple of pics in Nestor's ad. for the finished bike he has up for sale;
http://www.ebay.co.uk/itm/Fzr-400-1996- ... 19ef77000a
One problem you will encounter with this mod on a 3EN2 is the fact that the speedo drive is missing.
Without this, the bike will be restricted to 12k rpm as no signals are being sent to the TCI circuit.
This may be overcome by sourcing a M-Max derestriction box that plus into the loom.
Start sourcing one NOW; they are very rare at present.
Someone may be able to remove the restriction circuit at the TCI itself.( seems commonly done on the later 3TJ models)
If you don't "need" USD forks then a Thundercat front end will drop straight in
cheers evilchicken - no i don’t NEED usd's but they do the job + look the partEvilchicken0 wrote:If you don't "need" USD forks then a Thunder cat front end will drop straight in
im looking at a full engine swap with the front end to compliment would this get around the restriction as i plan
to use the full loom from the new engine?
cheers Ollie
The restriction is in the the CDI
so as long as i use the CDI from the new engine i shouldnt have a problem?Evilchicken0 wrote:The restriction is in the the CDI
im looking at doing a Fzr400 3en2 1wg - thunder Cat/ace (not decided yet) hybrid
Cheers Ollie
willandrip wrote:Get a YZF 750 shoehorned in !
that was my original idea but i had been told/read it wasnt do-able.....but if it is thats what il do
im up for a challange
cheers Ollie
May I humbly point to this;
viewtopic.php?f=37&t=43067
