NC23 Aero won't spark
Celis93
Re: NC23 Aero won't spark
Inside the switches.
Something I haven't mentioned yet: when I bought the bike, it didn't run.
When I pulled the spark plugs, they looked brand new.
So I think it just stopped running, and when they could't figure it out they just sold the bike...
Maybe this brings up some ideas on what the problem can be??
jonathan
I know you previously said you bypassed the clutch switch but have you checked the diode?
Just in case.
Just in case.
Celis93
I checked the diode, one way it is closed, the other way it has a resistance of 560 ohms.
Is this a correct value, or should it be close to 0 ohms?
jonathan
I think so long as it's closed one way and open the other it will be ok but I checked mine (1989 nc23 k)and it reads 890 and has 8.9 written by the contacts.
Celis93
I have used a test light on the coils, to make sure the coils get a pulse.
There is a current on the coils, but the voltage drops when I start cranking.
So the CDI isn't giving a pulse to the coils.
Is there any way to check for a pulse from the pulse generator??
Celis93
I opened my cdi and found a loose wire.
I think it should be on the open spot next to the yellow wire.
Does anyone know where the blue-white wire should be connected?
Celis93
False alarm, the white-blue wire should be disconnected..
It is an CDI-unit from Carmo electronics.
I really don't know what is wrong with the bike..
Celis93
IT'S RUNNING!!!
Apparently the jump cables weren't capable to deliver enough current to create a spark..
Thanks everyone for all your help!
dunkenb
Emzed
- Bike owned: NC23J/K,750Paso x2,MZ's,BMW C1
Well who'd have thought it
At least you know the electrics have had a good sorting
Just enjoy the buzz now
