derestricting the 3tj ignition
Morespeedvicar
Re: derestricting the 3tj ignition
Post by Morespeedvicar »
I think you could make a derestricter with a 5volt voltage regulator as I think the outline from the speedo seems to need to be held at 5v to stop the limiter kicking in. There a thread on here somewere with which colour wire is the supply and output somewere, i'll have a look tomorrow if you want when I not got a head ache!!!
I think I got a regulator kicking about in me parts box if you want to play.
Ian
ADG
Post by ADG »
Kayla850 wrote:You either need to mess with the CDI, fit an M-max/POSH box or mechanical speedo convertor to get around it (or mess with the insides of the speedo and trim the tab back).
As I see it, the 4DX CDI is already starting to fetch a premium price - and as M-max and POSH boxes are no longer available, then getting hold of a standard (unrestricted) CDI will become more problematic (read: not cost effective). Which is great news for parts horders, but not for people who just want to enjoy their bike - just look how ridiculous things are with the LC and YPVS :x
So anyone wishing to adjust their ignition is left with a limited number of expensive options - unless someone knows differently? :pray:
Whats involved with the internal speedo tab modification?
Post by Evilchicken0 »
You say expensive but a m-max or a speedo converter are about £30 each. The 4dx cdi starts from 50 ish but then you could sell your original cdi.
ADG
Post by ADG »
where can you get the M-Max still?
maccas
Post by maccas »
I did some cdi tests here:
viewtopic.php?f=37&t=44737
As far as i can tell there is bugger all difference between the standard 3tj cdi and the 'un-restricted' 4dx cdi. I reckon the advance curve and exup settings are the same. The only benefit the 4dx cdi has is that it doesn't have the speed limiter. Bendy's kit copy cdi made more power up top as it runs more advance. Once i get my bike working better i think the kit cdi will give me more of a benefit.
Personally i think the 4dx cdi fetches a false premium. Just remove the speed restrictor circuit board from the speedo, put it somewhere accesible on the bike and put something between the optics on start up then remove it once running. Then the bike is in unrestricted mode. This mod costs nothing, as does trimming the speedo tab down.
Dan
bendy3
Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Post by bendy3 »
When I get time I'm going to try doing a derestrict leaving the fuel circuit in for you road users but will need 1 of you to test it as I've only got race bikes. :grin:
ADG
Post by ADG »
bendy3 wrote:When I get time I'm going to try doing a derestrict leaving the fuel circuit in for you road users but will need 1 of you to test it as I've only got race bikes. :grin:
Happy to help if needed
Keny73tj
Bike owned: Cagiva Mito, FZR 4003TJ
Post by Keny73tj »
Anyone got any ideas as too what the small black box that was unplugged from my CDI if you read my earlier post this question may become slightly clearer!
Cheers guys :peace:
Keny73tj wrote:Anyone got any ideas as too what the small black box that was unplugged from my CDI if you read my earlier post this question may become slightly clearer!
Cheers guys :peace:
That would be a M-Max box or something similar
Keny73tj
Post by Keny73tj »
Thanks Evil, thought it was and to think I hunted high & low for one and only after swapping to a 4 DX unit it appears I had one all along!
