nc 35 questions
peavey
Re: nc 35 questions
Nice one ill try that , I picked up a working thermo switch yesterday but thanks for the offer .
Re: nc 35 questions
peavey wrote:well, got the bike sorted anyway and what a difference, engine feels far more responsive and everything,everything was going great until the law came on the scene. oh no i tought here we go. After me test run I came through town and was heading back to me house,next thing the blue lights were behind me. I pulled er over ,cop got out .turned out he was stopped behind a car at a side road just as I passed full of the pipe, he reckoned I was doin about 120mph but had only witnessed it and hadnt got the speed recorded on the gun.not so bad i thought , I actually felt like tellin him he was right caus im after derestricting it ''properly''. He gimme a caution and away I went.gona get it dyno'd now see what its putting out.
Thanks again everyone and ill get a few pics up soon :)
opps, I shouldnta posted that link.. you'll be busted now! be careful :)
RVFJE
Re: nc 35 questions
So if you just took the speedo out completely when turning it into a track bike (i.e. just disconnect all wires) and remove it from the bike what would happen to the speed restriction function?
Re: nc 35 questions
It will only run on 2 cylinders after 5000 rpm.RVFJE wrote:So if you just took the speedo out completely when turning it into a track bike (i.e. just disconnect all wires)
RVFJE
Re: nc 35 questions
That doesn't seem to have happened though. I've got some other problems but not that one.
So just in case what would I do to avoid it running on two cylinders having removed the speedo - this is an NC35?
Re: nc 35 questions
If it doesnt run on 2 cylinders with the speedo removed it probably already has the Speedo mod on there in the form of an M-max / hrc box or even a resistor
RVFJE
Re: nc 35 questions
So a HRC CDI eliminates the 180kmh speed restriction then?
As I disconnected the speedo and installed the HRC CDI at the same time I was preparing my bike for track only use that must explain it.
Thanks a million.
Thanks a million.
