'91 nc30 no pickup after change new cdi
dinv4
Re: '91 nc30 no pickup after change new cdi
Hi Stickshift ... pls give me the wiring diagram ....need urgently ....
All you need to do is find a wire that has power going to it (12v) when the bike is on. No power when the bike is off. Get a multimeter and find a wire like this.
Join the orange/blue wire to this 12v source. Simple.
- Jon
This shows how to hook up the resistor wire.
Ignore the rest of the wiring diagram as it is stripped down for a track bike.
http://i178.photobucket.com/albums/w278 ... titled.jpg" onclick="window.open(this.href);return false;
regards
jon
regards
jon
dinv4
Hi Stickshift ... I already put 12V wire to connected with orange/blue wire.the result is OK ( very smooth,like original ).
Hi Jon,do I need to put 2.2K resistor to loop with white/black wire.meaning that the black/white wire have 12V?pls advice me.
What will happen if I just tap wire 12V to orange/blue?( disadvantage )
What will happen if I just loop 2.2K resistor with white/black wire to orange/blue?( disadvantage )
really need your help on this ...cheeers
- Jon
Sounds like you have it sorted, as Stickshift said you just need a 12volt power source that turns off with the key.
Doesnt matter which one that is.
regards
jon
regards
jon
dinv4
Hi Jon ...
As I know is function of resistor is to constant/maintain the voltage .....
After putting 12V wire to my cdi,meaning that my bike already unrestricted????
