Page 3 of 4
Re: Electrical problem
Posted: Thu Apr 11, 2013 9:05 pm
by Jac-al
will do so when i can get it charged. reg/rec looks fine though, no burnt terminals or anythin. can it be stuffed without lookin so?
Posted: Thu Apr 11, 2013 9:08 pm
by bikemonkey
It doesn't often appear to be knackered, you have to test it to find out.
Posted: Thu Apr 11, 2013 10:46 pm
by Jac-al
ive tested it when connected to the harness plug but isnt there a way to test it on its own disconnected?
Posted: Thu Apr 11, 2013 11:34 pm
by magg
19 volts is way too much, thought you measure 14.2 volts in an earlier post. Battery voltage should never exceed 15 volts.
I would recommend you not run the engine again until you replace the rect/reg, otherwise you could damage the ignition control unit. It has probably already damaged the battery which is why it will not hold a charge and possibly why the battery cap blew off. A rect/reg that has a failed output control section will not usually show any outward signs of damage. They can be tested but it is a complicated process and they cannot be repaired if faulty anyway.
Posted: Fri Apr 12, 2013 12:12 am
by Jac-al
i did test 14.2 previously, is obviously gettin worse
Posted: Fri Apr 12, 2013 12:21 am
by magg
14.2 volts is ok, a maximum any wear between 14 and 15 volts is normal but over 15 volts is a problem. Is the rect/reg single 5 pin plug oem type?
Posted: Fri Apr 12, 2013 12:29 am
by Jac-al
5pin yes
Posted: Fri Apr 12, 2013 12:51 am
by magg
Best suggestion is to replace the rect/reg.
Posted: Fri Apr 12, 2013 2:57 am
Jac-al wrote:Still having problems. Just tested the battery at 5000rpm and it was at 19.3volts but when i try start the bike it just buzzes. Im sure the low beam relay mod i did is causin this?? Maybe i didnt do it right
This is overcharging.
Dont run the bike, the battey is most likely knackered too. Also replace the reg/rec.
After a new battery and reg/rec check the stator fully.
Member on here reently had the same and didnt replace the battery, killed the new reg/rec and the ignition box
Posted: Sat Apr 13, 2013 6:10 am
by Jac-al
just went for a 30km ride and stopped to put some juice, bike was off for 2min and when i tried to start it just buzzed. pomp joggie push started me an when i got home i tested the alternator and the reading was 1.6ohms. haynes says healthy it should be 0.1-1.0 ohms. what would be the cause of this?
