Page 3 of 3
				Re: Blue spot calipers
				Posted: Sat Apr 06, 2013 7:12 pm
				by StreetFZR
				Anybody know if the standard FZR4 master cylinder will be ok with blue spots??
I have just fitted some to my FZR1000 forks ready for fitting to bike, just need a master and might use mine and sell my callipers.
				Posted: Sat Apr 06, 2013 7:26 pm
				by Kayla850
				StreetFZR wrote:Anybody know if the standard FZR4 master cylinder will be ok with blue spots??
Hiya
It'll work but it'll feel really firm, it's better to use a 14mm one if you can. I think we've got one spare if you need one- swap for your 3TJ swingarm if we do?
				Posted: Sat Apr 06, 2013 9:38 pm
				by StreetFZR
				Hey
I will be up Tuesday or Wednesday, if you got one we got a deal
				Posted: Sun Apr 07, 2013 7:18 pm
				by Kayla850
				StreetFZR wrote:Hey
Okey dokey.
				Posted: Sun Apr 07, 2013 10:27 pm
				by Evilchicken0
				How does a 14mm stack up against a 19x20 or 18x20 ?
				Posted: Tue Apr 09, 2013 1:34 pm
				by Kayla850
How does the top fork leg bolt fasten on, or is it just being used as a pin and the lockwire is keeping in in place? There's not much room to fit a bolt head or nut behind there once the caliper is on. Is the caliper machined further in to clear the nut?
				Posted: Fri May 03, 2013 11:29 pm
				by mjh100
				Hi guys, blue spot calipers onto fzr400 3tj, you will need
Set donor blue spot calipers - they need sending in for machining to the two mounting arms
r6/r1 master cylinder ( im using r6 5eb - perfect ) - you can use std master but its not great !!!
offset bracket complete manufacture including new mounting bolts ( see attached pic )
available from PM Racing - ring Pete on 07980 926018
Lead time about 3 weeks
Ring for price
Done on my wet / twisty race bike, awesome results, can ring me on 07984073728 if any questions - hope this helps
all the best Mike
http://youtu.be/Epe4ykEoGuQ
				Posted: Sat May 04, 2013 11:27 am
				by CRM
				removed the double post
not sure why you submitted that twice.
