Blue spot calipers
StreetFZR
Bike owned: 3TJ 4/6 TURBO Streetfighter.
Re: Blue spot calipers
Post by StreetFZR »
Anybody know if the standard FZR4 master cylinder will be ok with blue spots??
I have just fitted some to my FZR1000 forks ready for fitting to bike, just need a master and might use mine and sell my callipers.
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
StreetFZR wrote:Anybody know if the standard FZR4 master cylinder will be ok with blue spots??
Hiya :grin:
It'll work but it'll feel really firm, it's better to use a 14mm one if you can. I think we've got one spare if you need one- swap for your 3TJ swingarm if we do?
www.projection-racing.com
www.pjcfasteners.com
StreetFZR
Post by StreetFZR »
Hey :smile:
I will be up Tuesday or Wednesday, if you got one we got a deal ;)
Kayla850
Post by Kayla850 »
StreetFZR wrote:Hey :smile:
Okey dokey.
Post by Evilchicken0 »
How does a 14mm stack up against a 19x20 or 18x20 ?
Kayla850
Post by Kayla850 »
How does the top fork leg bolt fasten on, or is it just being used as a pin and the lockwire is keeping in in place? There's not much room to fit a bolt head or nut behind there once the caliper is on. Is the caliper machined further in to clear the nut?
mjh100
Post by mjh100 »
Hi guys, blue spot calipers onto fzr400 3tj, you will need
Set donor blue spot calipers - they need sending in for machining to the two mounting arms
r6/r1 master cylinder ( im using r6 5eb - perfect ) - you can use std master but its not great !!!
offset bracket complete manufacture including new mounting bolts ( see attached pic )
available from PM Racing - ring Pete on 07980 926018
Lead time about 3 weeks
Ring for price
Done on my wet / twisty race bike, awesome results, can ring me on 07984073728 if any questions - hope this helps
all the best Mike
http://youtu.be/Epe4ykEoGuQ
CRM
Admin NWAA
Admin NWAA
Post by CRM »
removed the double post
not sure why you submitted that twice.
