GK76a Exhaust
- Bike owned: GSXR400SP GK76a
Re: GK76a Exhaust
I haven't actually got any yet but I am definitely considering getting the stainless steel ones. The ones currently on mine are pretty much shot to pieces and theres only so much repair work you can do to them! I know theres a supplier on ebay at around £220.
Re: GK76a Exhaust
Ok so I'm going to get the ss header pipes next week. I havent looked at the bolts in the head yet and im dreading as to what condition theyre going to be in! As i havent looked at them yet does any one know what they are? As in are they alan bolts, normal bolts/studs??? I imagine theyre going to be pretty rusty and releuctant to come out so a good old go on an impact driver will be a must i think. If anyone knows exactly what they are it would be great to know so i can order some more so they arrive and i can put the new ones in straight away.
Re: GK76a Exhaust
also... anyone know if i can get some ready made gaskets for the ports?
- Bike owned: Gk76a x2
Re: GK76a Exhaust
They are Allen head bolts or they should be I can't remember what size if you ring robinsons suzuki they can get the originals no problem. If I was putting those headers on I would get some in stainless any way and the heads won't shag on you in 5 years time like the originals do.I've just taken my headers off my other 76a I cleaned the Allen heads out and never left one bit of shit in them and got my cordless drill driver on them using the clutch and rattling them for a while increasing the clutch setting each time then got the ratchet on them and they came out easy . Exhaust gaskets you can get from robinsons aswell
Re: GK76a Exhaust
Awesome, do you know the part number for robinsons?
Re: GK76a Exhaust
Ok so I got everything I need.
SS header pipes (£229.99) from:
http://www.ebay.co.uk/itm/GSXR400-GSXR- ... 232a255070
Gaskets, new bolts to go into the head, metal clutch plates & new spring bolts (£90)from:
www.robinsonsfoundry.co.uk
And the clutch friction plates and new springs from ebay (£60) also...
All pretty much a striaght forward job, lets just hope and pray that bolts DONT shear off in the head
Donk, when you did it i assume you had the rad off completely? Also did you get the front wheel off aswell? And when you say cordless drill are you on about a nut runner/impact gun? or literally a cordless drill with an alan key in it!?
Re: GK76a Exhaust
Yea rad off but keep the front wheel in I used a cordless drill driver with a clutch just because I don't have a impact driver
Re: GK76a Exhaust
Ok I'll give the cordless drill a go then mate. Did you put anything on the gaskets or just leave them as they were? Finally, did you torque the bolts back in, if so what to?
Re: GK76a Exhaust
As they were mate . I just did them up tight but I didn't have a jap manual then . The manual is hard to understand but I'm sure they are torque to 18Nm first then 27Nm
Re: GK76a Exhaust
Thanks Donk I'll let you know how I get on at the weekend (If everything has arrived by then)
