Page 3 of 5
Re: Re: Ebay, won rear disc,
Posted: Fri Dec 07, 2012 7:52 pm
by speedy231278
pip wrote:
The disc below has done 74000 miles, 68k in my ownership.
Where are the grooves.....
IMHO, all over it! Very insignificant ones and normal light wear, apart from the score around the outer edge of the holes which is a little more pronounced. If it were on my bike, I'd not be bothered in the slightest. The rear disc that is the subject of this thread, however, would have been consigned to a skip long ago!
Posted: Fri Dec 07, 2012 8:00 pm
by xivlia
pip wrote:xivlia wrote:i dont see how that disc looks that bad? its got lines on it because of the ceramic pads... every disc WILL have that unless its brand new and not been used for too much.... you should see the state of my current one... il take a pic and post it up on here to see what i mean....
but yeah, if this one is bad or below 5mm il chuck it out...
You do talk some crap.
Maybe you should have asked for the exact thickness before you shelled out over 20 quid
Pip
i dont know where your coming with the "grooves" as there are No groves on that disc... there are lines... caused from the pads. its probably ceramic deposits thats been left on there from the pads.. bare in mind, discs vary from brand to brand, and not all brands use the same alloys to make the discs. and most pads are also different, so a combination of different discs/pads could cause more pronounced lines to appear on discs, because different alloys react with different heat that is caused by the friction of the pads.
Posted: Fri Dec 07, 2012 8:02 pm
by pip
porndoguk wrote:Arguing, disagreeing etc all aside,
If the disc measures below 5mm ersan you have every right to file a claim as the seller has misold it.
So dont chuck return it for a refund.
Rick
Blob on, good point
Posted: Fri Dec 07, 2012 8:16 pm
by alexwitham
I love you
Posted: Fri Dec 07, 2012 9:51 pm
by porndoguk
http://img.tapatalk.com/d/12/12/08/ana8u5yg.jpg
Pip
sort your picture links guvna
Posted: Fri Dec 07, 2012 9:53 pm
by porndoguk
alexwitham wrote:I love you
Sword fight?
Posted: Fri Dec 07, 2012 11:04 pm
by billnit
I love these threads....
Posted: Fri Dec 07, 2012 11:35 pm
by alexwitham
Sword fight?
Mate honestly this guy is such a hero. I click any new threads by Xivlia just so I can laugh my genitals off.
Re: Re: Re: Ebay, won rear disc,
Posted: Fri Dec 07, 2012 11:58 pm
by pip
xivlia wrote:pip wrote:xivlia wrote:i dont see how that disc looks that bad? its got lines on it because of the ceramic pads... every disc WILL have that unless its brand new and not been used for too much.... you should see the state of my current one... il take a pic and post it up on here to see what i mean....
Pip
You say that all discs will be scored unless new or very nearly new, the pic is to prove that that's not the case.....
porndoguk wrote:pip wrote:xivlia wrote:i dont see how that disc looks that bad? its got lines on it because of the ceramic pads... every disc WILL have that unless its brand new and not been used for too much.... you should see the state of my current one... il take a pic and post it up on here to see what i mean....
Pip
Done!
Oops - I forget as they come up perfic on the 'phone, keep giving me a prod!
Posted: Sat Dec 08, 2012 12:33 am
speedy231278 wrote:Ummm.... 4.8mm thick, and the service limit is 5.0....
Argh yes! I shouldn't post half asleep. I read it as 4.8mm of wear left to wear (remaining) not remaining on the disc.. stupid now I think the original wear area is only 2mm.
For clarity in this thread.
OEM discs
Fronts are 4mm with 3.5 being the service limit.
Rear is 6mm with 5mm being the service limit.
