Juggernauts labour of love NC30
juggernaut
Bike owned: LUKE@YORK on the old site!
Re: Juggernauts labour of love NC30
Post by juggernaut »
Today's swag.
Hrc style air box
41 tooth rear sprocket
Stainless fasteners
NGneer
Post by NGneer »
Nice :drool:
:popcorn:
juggernaut
Thanks!
Just spent the last hour dremaling the flanges off the 748 clear lens so it all sits flat and silicones it in to the aperture of the carbon seat unit, will look real nice with the clear OE indicator lenses.
Then dremaled most of the red lens out of the rvf stop tail light and fitted the red bulbs.
Should be able to get it on tomorrow once it all dried
Also had to do some minor cutting to the vfr under tray as the width was very wide and didn't want to risk the carbon seat every time I take it off.
cranton123
One Hit Wonder
Post by cranton123 »
[quote="juggernaut"]748 clear rear lights to mod in to the rvf stop tail lights[/quote]
Would like to see how you mod your rear light
And where did you get the 748 Clear Lens from ???
juggernaut
Looks pretty messy.... But you won't see the inside when it's on
juggernaut
Finished result
porndoguk
Post by porndoguk »
looking good fella what nose cone you fitting then?
juggernaut
porndoguk wrote:looking good fella what nose cone you fitting then?
I was all set to have tyga do an RVF carbon upper and only cut one hole out like ABR's rvf, so ordered the seat and lowers as funds allowed and a few weeks later emailed them about the upper and they said it wouldn't be a problem But they had stopped producing the upper for a while, just said they had production problems with... Was very dissappointed....... I even have the front nose cone bracket on order with a forum member and I'm picking up a set of rvf headlights today!!!
Plan is to still go ahead with this plan when tyga sort out their problem with the rvf upper, in the mean time I'm thinking silehouette upper in plain white to match the tanks, one headlight and a couple of HRC stickers.
Seems about all I can do.
IM OPEN TO IDEAS THOUGH, if anyone has them
New tyga 41 tooth sprocket and clean tsubaki heavey duty gold chain clean ready for dry lube instead of wet... Hate wet lube the nc wheel is sooo hard to clean!
juggernaut wrote:lan is to still go ahead with this plan when tyga sort out their problem with the rvf upper, in the mean time I'm thinking silehouette upper in plain white to match the tanks, one headlight and a couple of HRC stickers.
You mean like this :whistle:
I still have the nose and mids sitting in the loft
With regards to the front bracket your be better off modding the VFR one, the RVF one wont bolt up to the VFR frame without cutting off the mounts and having new ones welding on. And then you have the hassle of getting it in the exact right position.
juggernaut
Yeah pretty much like that until tyga do the carbon upper again, do you have any pics of the modded vfr stay? Drunkn? More than likely give it a go using the vfr stay then.
I'd be very interested in a silohoute upper that incorporated the mids in to a one piece unit for either the vfr or rvf.
