1wg will not start
Re: 1wg will not start
oooff - not a difficult job if you have the tools.
You can still get good 18" tyres and if you're not fitting them yourself then ask the tyre fitters what they have ... round and black still have some bt090s
t-rex
Hi do i need any special tools to do the job or will my snap on chest have the tools in there somewhere.
You'll need the seal dibby down tool - it's in the second drawer down in the roller cab
- Hogdigerdy Dog
and if that fails use your snap-on chest, there's nothing like a bit of brute forceEvilchicken0 wrote:You'll need the seal dibby down tool - it's in the second drawer down in the roller cab
as for the bike, the fork seals are not too big an issue to fix, several threads on here about that,
BUT i'd leave the tyre fitting to a tyre fitting type person, or the end result will be buggered up rims,
it only cost's about £15 a tyre (£12.50 local to me) so well worth the £££
t-rex
Cheers lads that was genuinely very funny,if you could point me in the right direction to the threads i would be very grateful. ta,
threads are on the bolts matey
Here to help
Here to help
hunter
Don't forget they'r in the nuts to.
willandrip
If your still on about tyres;they have TREADS not THREADS.,but a good rider should be able to get the treads to the threads before tyre is discarded.
t-rex
actually i'm on about fork seals not fur seals or grey seals,just fork seals.
willandrip
"Dont mind grey seals,dont mind common seals dont even mind elephant seals, it's imbeciles I'm not so struck on". (No offence intended,just an old saying of mine!!!!!!)
