NC30 bogs down
RegionX
- Bike owned: VFR400 NC30
Re: NC30 bogs down
I had a look at mine recently and for a couple minutes thought I had the same problem but turned out that I could see 3 pilot screws looking from one side and only one from the other (obviously I thought I would see 2 from each side) Have you checked all carbs from both sides?
NC30Dubz
- Bike owned: VFR400R NC30 (Polly)
Re: NC30 bogs down
not yet.. i will be taking the carbs off again at the weekend, havnt really got time during the week to disassemble the bike. Thanks for that though, i will remember to look
Re: NC30 bogs down
Check that you're looking in the correct spot on the carb body. This pic shows one of the pilot screws, all 4 are on the inside of the carbs:NC30Dubz wrote:As i havnt had to deal with pilot screws before, im 99% sure that i am looking in the right place according to my manual. I will get a picture when i get a chance to take the carbs out again
Don't confuse them with the float bowl drain screws which are located on the actual float bowls, not the carb body.
This pic was taken from the carb jetting thread - plenty of other carb pics which might help you: viewtopic.php?f=24&t=14524&start=0
I'd be very surprised too if it idled if you were missing the air screws, though I've never tried this!
NC30Dubz
Re: NC30 bogs down
Thank you for the carb thread, i found it highly useful. In conclusion, the bike now runs fine. i found the pilot screws, ( i was looking in completely the wrong place, and although i could see the pilot screws, i thought they were something else as i wasnt expecting to see them facing inwards ) i turned them all the way in, then back out 2 turns, made sure everything else in the carbs was in the correct place and clear of debris etc, took her for a run this morning and.. it was amazing, i had forgotten how much power she has through mid range. Again, thank you for the thread. Most useful :)
