HEL Rear Brake Line - Too Long?
lizard821000
Re: HEL Rear Brake Line - Too Long?
i just used the ones that come off the old line mate, thats why i have more.
i put the line on first then thought the same, so got my old gromets, sliced them down the middle and popped them over the line and moved them to where the chain guard clips where and pinched them down.....job jobbed.
plus there should be a metal retainer clip on the rear swingarm pinch bolt....to hold it away from the wheel, i dont have one either but might put something on for good measure.
HTH
HTH
arsey30
- Bike owned: ftr223 650 bros
The chain will not run in correct alignment, so more wear and friction.lizard821000 wrote:lol, is it!? will it matter
It will not be much as the chain is wider than the sprockets so can move to try to take up its proper run.
You may see a shiny wear line on the outer face of the teeth.
It is simple to reverse.
oldgreyandslow
- Bike owned: 1990 NC30
I knew I shoud have kept the old ones! It certainly looks better than having the line loose in the clip, I have the retainer clip on the pinch bolt though.lizard821000 wrote:i just used the ones that come off the old line mate, thats why i have more.
i put the line on first then thought the same, so got my old gromets, sliced them down the middle and popped them over the line and moved them to where the chain guard clips where and pinched them down.....job jobbed.![]()
HTH
MostyVFR400
- Bike owned: 1989 Honda VFR400R NC30
I've just come up against the same problem. See photo.
The HEL line measured 1m 22cm and the original 1m 10cm. As you can see it's nearly touching the wheel.
Obviously in the photo i have none of the other parts fitted, IE chain guard etc, but did have them on for dummy run of brake line. so everything was as it would be once the bike is finished.
I basically contacted the guys at HEL to let them know, sent it back to them and received it back the following day, cut to the correct length. They were really helpful.
Austin
Austin
arsey30
Another sprocket fitted back to front, shiny tooth faces indicate misalignmemt.
lizard821000
would it make a differance though?? as wont it just wear on the other side instead!?
surely the chains sametrical.
nazzurro_19
- Bike owned: Honda NC30
Anybody tried the wezmoto one off ebay for £19.99
- Deviant400
by having the sprocket on that way it makes it slightly off set , having the lip/groove on the inside will fix that basically the centre of the sproket is milled out causing the lip around the edge, it brings the sprocket a fraction closer to the wheel
viewtopic.php?f=62&t=27307
lizard821000
ahh reet, i got the bloody chain on now and the pinch bolt at the back was threaded , so a longer bolt was used and pinched tight, i dont fancy undoing it tbh.
long as im not gunna die or anything ill leave it.
StrayAlien
I had them redo a rear line four times (yes, four) before giving up and sending the actual rear to them so they could copy it. If it wasn't a length error it was a connector shape or angle error, or all three. Took about 3 months all up. Sort of dissapointing really ...Em sea 19 wrote:HEL are notorious for length errors
Lesson? don't assume just because it has you bike model on the box that it is correct. If you are unsure, get onto them.
