no neutral light and wont start without clutch being pulled
phil x
Re: no neutral light and wont start without clutch being pul
An easy way to eliminate whether it's a wiring or switch problem is, pull the wire off the switch & with ign on ground the wire to earth - the neutral bulb should illuminate.
You could do a continuity check on the switch.
Sometimes the connection just wants a bit of a clean up, I have had success with removing the sealing washer to give the plunger better contact.
In fairness, it's very unlikely that a switch will actually fail.
